Saloon RS3 sunroof query
Tristan2 Jun 3, 2018
  1. Tristan2
    Tristan2 Guest
    went out yesterday parked the car at home on the drive with the sunroof open locked the car hour later got back into the car sunroof still open
    Drove to the pub sunroof still open parked up locked the car,came back to the car hour later and the sunroof was closed
    WHY??????
    Rob2k68 likes this.
  2. Avatar
    Google AdSense Advertisement
  3. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User MQB Platform
    7,337
    11,129
    Did it rain ?
    Sent from my iPhone using Tapatalk Pro
  4. Tristan2
    Tristan2 Guest
    No Rob
    How’s you mate?
    Rob2k68 likes this.
  5. Rob2k68
    7,337
    11,129
    I’m good mate thanks, hope you are too
    Just wondered if rain closure of sunroof is now on by default as it used to be a VCDS tweak.
  6. Rob2k68
    7,337
    11,129
    Long press of key (global closure) whilst keyfob in pocket ?
  7. Tristan2
    Tristan2 Guest
    It definitely didn’t rain,so I’m a bit confused
    Rob2k68 likes this.
  8. monopole
    monopole Guest
    I know comfort closing of the sunroof, when rain was detected, was never a functionality of the PFL cars (and never actually worked when trying to code it in as far as I am aware) but would be interesting to know if it now a functionality of the FL cars, i'm pretty sure @DJAlix would be able to confirm this?
    Could be your were inadvertently pressing on the lock button on your key fob which closes all the windows, so can you say if;
    - sunroof and side windows were open when you left the car, all windows closed on returning, or
    - only sunroof open when you left the car and closed on return
    - sunroof and side windows open when leaving the car and only the sunroof closed on return?
  9. Rob2k68
    7,337
    11,129
    Don’t think it would take much rain - try drumming on the rain sensor with your fingers with the car locked and roof open.
  10. Tristan2
    Tristan2 Guest
    Only the sunroof was open when I left the car,sunroof closed on my return
  11. T-800
    T-800 Well-Known Member VCDS Map User It's my birthday
    3,273
    3,203
    Just tried this on mine
    No amount of water or tapping the sensor made it close
    I’ve left the pano roof open on warm days and it’s always been open when returning to the car.
    The rain closing never worked on my my PFL car so never bothered trying it on the FL.
    Saying that if rain was imminent I’d never leave the windows/roof open anyway.
    AudiNutta, monopole and Rob2k68 like this.
  12. Avatar
  13. monopole
    monopole Guest
    then I think it is likely to be from an inadvertent press/hold of the lock button on your key fob
    AB RS3 and RGBARGEE like this.
  14. AudiNutta
    AudiNutta Well-Known Member Team Racing Blue Mica Sportback Audi RS3 quattro
    6,575
    4,166
    Haven’t got pano roof but if I leave my windows down, lock the car and walk away.. within about a minute they all go up on their own... every time.
  15. Spinstorm
    Spinstorm Well-Known Member
    1,282
    564
    Talking about the sunroof mine is now rattling - time to go to the dealer again...
  16. billymc92
    billymc92 2018 Ara Blue Facelift RS3
    633
    702
    93
    I thought I’ve had this the last couple of days, was a knocking very loudly above my head and thought it was my sunroof after reading everything on line. Turns out my sunvisor had not been clipped back in to its slot properly and it was that knocking away. What a relief it was just that!
  17. Spinstorm
    1,282
    564
    Its definitely my sun roof - as it stops when it is fully back. It initially was only when the roof was tilted open and now its doing it all the time.
    My S3 had the same problem - they replaced the sunroof frame under warranty which took about 5 days to do and that fixed it.
  18. TurboBen
    TurboBen Active Member
    212
    103
    43
    I've had pano roof on my S3 and now my RS3 and hsd rattles with both. S3 was when fully open, RS3 is when fully closed.
  19. royalsteve68
    royalsteve68 Well-Known Member TeamMisano Team Ara Blue Audi S3 Audi RS3
    1,614
    486
    Never leave your car parked with roof or windows open as you are not insured, privilege insurance stipulate this abs I'm pretty sure all other insurers are the same.
  20. RGBARGEE
    RGBARGEE Well-Known Member Team Mythos Team Daytona Team Phantom Audi S3 Audi RS4 Audi RS3 Audi A1 Black Edition Navarra Blue Classic
    2,021
    1,483
    My late wife had issues with her 8P Pano roof. She had the car for 3 years and for 2 of them it rattled. I suspect the problem was a minor car park ding and the car being repaired and then baked in oven. The rattle only started after the body repair. Eventually we had whole roof replaced, they are glued in apparently. Very annoying!
  21. Spinstorm
    1,282
    564
    My car is booked in for the 28th but we are looking at 2 weeks probably for them to take apart the roof find the problem and order replacement parts from Germany. Audi CS is going to see if they can get my an RS car to use as a courtesy car so I am hopeful for that. Also going to check out my squeaking brakes.
  22. Snake Pliskin
    Snake Pliskin Well-Known Member Supporter Team Floret Silver Audi RS3
    3,979
    5,671
    I really would like a pano roof but the dreaded rattles are what have put me off each time.
    These cars rattle enough without adding the potential for more rattling :blink:
  23. AudiNutta
    6,575
    4,166
    You really know how to pull the strings, fair play. Have they heard the rattle before agreeing to this? Do you go through the annoying 3-day case opening stage with Audi UK?
  24. Spinstorm
    1,282
    564
    First of all they havent confirmed to me that I will get an RS car yet however if it wasn’t possible I assume they would just say that to me. The exact words were they can’t confirm availabilty of an RS car for me as they don’t know the date - so I told them and we will see. I havent heard back yet.
    This is all related to the original steering wheel issue, followed by the engine managment issue so it is the same case. And it’s with the executive care team not just my local dealer. The dealer said they would give me a standard car which didn’t impress me.
  25. AudiNutta
    6,575
    4,166
    Yeah I appreciate that, getting them to say they would try is something.
    Ah I see then, so you’re just going back to a case manager. I’ve opened 2/3 complaints with Audi UK and every time they’ve given me the same case manager, he is great and spends ages on the phone just chatting (but constructively, before Audi sack him) I love it.
    If you actually get a standard car you will be even less impressed than the concept of it ;) Q2 is common these days. Service simply don’t have nice cars on fleet out of the Audi Sport range, they should because I always see Audi Sport products in for service when I go in but it’s all cost isn’t it.
    sve170 likes this.
  26. Spinstorm
    1,282
    564
    So I have had confirmation that Audi have asked for an RS car for me when I take my car in tomorrow/Friday.
    I am expecting a call tomorrow to confirm which car. But could conceivably be another RS3 or RS4/5/6. We will see.
  27. Snake Pliskin
    3,979
    5,671
    Will probably be an RS4 as I am sure they will have a demo with that being the newest RS car.
    I'm never that fussed tbh when I take my car in and just take what they give me.
    To be fair it is usually something decent be it a TT, A7 or S3.
  28. teslaboy
    teslaboy Mythos black RS3 8v FL Audi S3 Audi RS3
    763
    469
    Getting RS as a loan car is pure chance.
    Just because you bought an RS does not mean Audi have to give you one when your cars in for warranty work etc.
    Not a chance in bell.
  29. Behind The Bins
    Behind The Bins Well-Known Member
    345
    254
    +1 I dont care what I get as a loan car, as long as I'm mobile. Its a 'courtesy' car, in reality they can give you nothing and say if you dont drop it off we cant fix it.
