Retro fit cruise control
zxzzxzxx
Birmingham
Hi guys. I've a 2008 A5 quattro which doesn't have cruise control. Having called Audi and others direct I'm told it's not possible. However there's a chap on eBay who assures me his able to supply. Can anybody advise if perhaps I supply vin or registration number?
Many thanks
CC can be fitted, just needs the correct part.
Post a pic of your current stalks as it's a full set & I have a set as it happens, so I'll see if it's compatible.
When you put your high beam on does the stalk stay forward or spring back to the middle.
Hi NHN
The high beam stays forward once engaged and doesn't spring back.
Yeah I have a set of stalks for CC, I assume you're fitting yourself. Message me if you would like to purchase them.
I'll not be installing but I'll get some one to do so. Do you have the part number of the one you have?
The only issue is I need to make sure the slip ring is the same. And how much are you after?
Many thanks
It comes with the slip ring this one & I've checked it's compatible.
As advised, ping me a message if you'd like it.
I do of course install aswell.
I travel to installs, WhatsApp on my signature & message if you're seriously interested in either the part or the supply fit overall, no messages for DIY installs please, thanks.
659
NHN
10
957
