I got an issue with the rear near side door not opening from the outside after unlocking the car. It opens fine from the inside, but when you lock the car and then try to open it using the handle outside of the door, it stops working. However, once it's unlocked it opens from the outside perfectly fine.
Child lock is off, so I can rule that out. I'm guessing the central locking door mechanism is at fault here?
Any help would be appreciated, thanks
