maybe just some fine tweaks to the camber will be enough Jon , your local tyre guys should be able to sort it out, I think its because your rims are 6mm wider on an et35 than they would be if you had the same offset but 8j rim , so are nearer to ET 29 tyre position wise on the rear now .
