So, I've been looking at flywheel and clutch options for the C5 RS6 motor.
As I have opted to run a regular 077-series V8 40V engine, I have more flywheel options open to me (8-bolt fitment to crank). I was considering the popular B7 RS4 flywheel and clutch, but having spoken to TTV Racing, as well as quite a few respected tuners in the UK, Europe and the United States, there's no proven benefit in running the B7 RS4 clutch over a B5 RS4 item.
If anything, the B5 RS4 pressure plate has been tested in different rigs, and it has more clamping force than the B7's. Torque wise, both the B5 and B7 RS4 engines produce similar torque outputs - 440 and 430Nm respectively. The B5 RS4 however produces its torque much lower down the rev range, which loads the clutch up more. Put it this way, 450Nm produced at 2,000 rpm is more destructive to a clutch than 500Nm produced at 6500. One of the reasons why it's popular to run diesel flywheels and clutches in big power gasoline motors.
The RS6 4.2 V8 BiTurbo (BCY) engine produces 580Nm between 1,950 and 5600 rpm. A very wide, and useful power band. It almost doesn't matter what gear you're in, it'll pull strong. Very different from a highly-strung, properly built 1.8T making 550hp. The power band really matters to me.
Engine will be with me by Wednesday, and I'll be ordering my flywheel sometime next week.
