Again.the only way of making a catch can system work properly is by deleting all of the breathers venting into the engine,and the IE system does that,but at a price.
Sorry to jump in again Michael as where on the topic of Pcv I fitted my forge one yesterday. Does the Pcv prevent the rough idling when the dipstick is removed as I pulled mine out yesterday to check the oil and it didn't change?
Also I know the engines tick quite a lot but mine seems quite noisy the trouble is how noisy does it have to be to start investigating
I will most likely go down the IE system eventually but cant afford just yet , Niki just mentioned that my idle was slightly lumpy and there was a small amount if residue around the pcv so advised that i change it out .
