The car is using a bit of oil, little leak on the rocker gaskets but it seemed to do it more after a bit of fast driving. Had a little bit of random smoke coming from it, panicked at first like you do owning an S4 but have managed to put it down to clogged pcv/breather pipes, same happened with the spider hose on my B5 S4
It's not smoking enough or consistently to be the valve seals or scored bores
So I cleaned the 2 pipes coming from the rocker covers and they were pretty crudded up with sludge, swapped the pcv valve out and took it for a spin, zero smoke at all.
Whipped the pipes off again to see and noticed that the T piece they connect to had some sludge in it also
Couple of questions;
I know that from the T piece there's another pipe that leads off down to the driver's side of the engine but can't see where, anyone know?
Also if I can't clear the pipes out what are the part numbers for a new set of hoses and I'll prob put a new suction jet on there too
Engine code is BBK
Thanks in advance
Engine code is BBK
Thanks in advance
