Noise on tickover when cold
rodenal
Since about last week, when i start the car from cold on tickover its making a weird sort of, well ticking. It's fairly loud makes it sound diesel-ish
The noise changes speed with the revs and has definately only just started occuring.
Only happens when cold, clears up within 5-10 mins.
Doesnt seem to affect the driving of the car in any way either.
I havent had time to get underneath the car to try and check exactly where it's coming from, but i dont like the sound of it.
Any suggestions as to what it might be are welcome
rodenal
Oh yeah, '97 1.6
Ian W
Probaly just hydraulic tappets, try an oil change, normally sorts them out
*experience on other cars, not audi's :)*
rodenal
It's not really rattling, more of a tick just louder than usual - plus if it was the flywheel wouldnt it occur all the time not just when the car's cold?
Aky
Aky
mine only started rattling when I first started it up then got worse. If you dip the clutch does the noise disappear? if not then its not clutch/flywheel related.
rodenal
Nah it stays even with the clutch dipped, im about to service the car this month anyway so ill see how it reacts to that.
Just a pain in the *** this starting now as im gonna sell it soon!
satanmademedoit
I'm with the tappet suggestion, and a motor will never refuse a good oil change even if it doesn't sort your problem,... always money well spent!
(I also have not much Audi experience so be gentle....):)
VAGMAN1
definitely the hydraulic tappets - you could try using an engine flush such as that by Forte - the problem happends as the lifters get caked in oilly crud over time, thus stopping oil getting in to them as soon as would normally be the case - hence the ticking noise which is un-lubed metal-on-metal
