New to vcds
niedzial1983
Apart from simple mods, autoscan how can i check the engine for issues ?. I have seen people checking compression, etc...
So im looking for some help and advice how to check the car
2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
If you print the manual it's very clear how to do a number of things, i have helped a few of the lads at work because I had it. Did some coding on an a6 today
You can't check the compression with VCDS. There are lots of things you can do but if you have no fault codes or problems with the engine it's difficult to know where to start. Most common issues with these engines are swirl flaps or dodgy injectors possibly.
As long as you don't have white smoke injectors are probably good.
There are plenty of videos and info available.
Reactions: niedzial1983
767
862
NHN
864
