New B8 owner and panaramic sunroof water leak!
bhodgkiss Dec 5, 2018
  1. bhodgkiss
    bhodgkiss Member
    43
    Hi All,
    I've just picked up a 2008 B8 3,0TDI Avant at a good price, so looking forward to some time on this forum.
    I know members such as Karl with the 380bhp+ 3.0TDI so know there's some good guys on here.
    So to start with.... I need to sort a water leak around the panoramic sunroof. The rear right seat is wet and headlining above.
    I believe I first need to check the front and rear drains? So peel back the rear wheel arch liner and access the rear drain from there?
    Any help appreciated - ive done a few searches and found various info, but was hoping this thread might end up as a useful one as I'll put all the info on here.
  2. Avatar
    Google AdSense Advertisement
  3. spartacus 68
    spartacus 68 Active Member Team Ibis Audi A2 Audi Avant Owner Group quattro
    497
    97
  4. bhodgkiss
    bhodgkiss Member
    43
    Many thanks
    Also two other niggles please:
    - The front passenger seat rattles when going over bumps (when no-one is sat it in, its a proper metallic tapping sound. Looks to be the upright part of the seat buzzing around
    - Left headlight washer pops out but doesn't pop back in! Is there a common fault on this please?
    Ive got vag-com and its not thrown up too many issues in general.
  5. MuPPeT_ON_TouR
    MuPPeT_ON_TouR Well-Known Member Supercharged TFSI Owners Group Team V6 Silver Supporter Sportback Audi S5 quattro Black Edition OBD11 USER Deep Black Pearl DSG
    462
    260
    Headlight washer is very common to be faulty and leak. And not a cheap fix.
    Front bumper off and replacement washer job.
  6. spartacus 68
    497
    97
    Regards the rattling seat, ideally you want to remove from the car to access it from both sides. Be aware if you disconnect from the car it may throw up errors, fine in you have VCDS. Not sure just how much you can adjust on these seats, as something is either loose or worn. Had a similar rattle on the passenger front seat on my B5 V6 quattro. Ended up turning up the CD player! You might be able to adjust, or add a little foam padding if it's metal on metal.
  7. bhodgkiss
    bhodgkiss Member
    43
    Many thanks!
  8. cyhliu
    cyhliu Active Member
    140
    53
    I recently had the same issue with my panoramic sunroof and I managed to fix it without too much trouble. Please see my thread;
    https://www.audi-sport.net/xf/threads/water-ingress-rear-passenger-side.380440/
    I cleaned out the drainage hole in the rear wheel well following instructions from one of the links in the thread. So far haven't had any further leaks (touch wood!) and we've had a fair bit of rain since I cleaned it out.
  9. bhodgkiss
    bhodgkiss Member
    43
    Many thanks
    I don't actually have water in the car at the rear.
    Both front footwells are wet, and when the roof opens it dumps water onto the rear right seat.
    What is the special tool to remove the grab handles when doing the headliner please? I might as well buy one :)
  10. Russboy
    Russboy Active Member Supercharged Audi S4
    508
    242
    43
    spartacus 68 likes this.
  11. spartacus 68
    497
    97
    Given its winter then you really want to minimise damage to the car. It's amazing just how much water can come in the car, so dry off the carpets, and get some plastic sheeting down there. Tape off where the water runs down the footwell plastic trim to capture it, otherwise you're in a world of **** as the soundproofing under the carpet will suck it up.
    This is quite a good guide for the tool for the headliner handles. https://www.audizine.com/forum/showthread.php/701896-B8-A4-DIY-Headliner-Removal
    I'm still trying to solve the issue, and short of spending £800 for a new cassette which may or may not solve it, I'm trying this. https://www.yetiownersclub.co.uk/forum/uploads/10/Yeti_Panoramic_Roof_Leak.pdf
    I ordered the Captain Tolley's sealer. Sure saves opening the roof lining again, (bear in mind I've been in there more times than a surgeon doing a routine appendix operation). Plant to put Sikaflex 291 (black) over the top too from the outside.
  12. Avatar
  13. spartacus 68
    497
    97
    Good news. The drain channels where the tube connects is very poorly designed, what were Audi thinking?
  14. bhodgkiss
    bhodgkiss Member
    43
    Just an update, the sunroof leak was blocked drain holes in the channels on both sides of the sunroof itself, 3/4 the way towards the front of the sunroof. So not the main front and rear holes
    Too much grease has been applied in the channels, which blocked the hole on each side, which then caused water to pooland overflowinto an area which it shouldn't, thus dripping inside the car.
    It's certainly not dripping in now, so seems to have cured it.
    Aside the headlight washer jet issue is a simple misalignment between washer jet and front bumper hole (see below)
    Can the washer jet assembly adjust in position to better align with the bumper please? Ideally it needs to go 5mm to the right in the photo below
    http://i752.photobucket.com/albums/...5-798D-41A6-BE9D-B7D11F4CBD15_zpsxihq0qv6.jpg
  15. Russboy
    508
    242
    43
    I should have kept quiet! Noticed drips in the passenger front footwell. Thankfully as I know what to do now within 5 mins of looking I had the roof lining down on that side the drain hose was loose again. Taped up and then cabled tied into place, not going anywhere this time!
