I guess you could do that, check to see if you have a wobbly tyre or tyres and compare this with the play in the fronts. If you can't notice a difference, it may be best to get them checked at your local garage.
Most wheel bearings these days get noisy rather than exhibit play. Jack the car up and spin the wheel listening for the usual dry/whirring noise. It should be completely silent when turning (light brake pad scrape aside)
Check as well that your tyres are ok. I was all set out to buy replacement bearings for my old TDI but turned out that the tyres had twisted and were causing noise due to bumps in the tyre - cheap nasty BCT tyres (never again)
