Wednesday,02,January,2019,18:58:17:51675
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.4 (x64)
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8T99A014385 License Plate:
Mileage: 297550km-184888mi Repair Order: A5_audi_forum_help_faults
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 10 13 15 16 17 18 19 1E 36 37 3C
42 46 47 52 53 55 56 69 6C
VIN: WAUZZZ8T99A014385 Mileage: 297550km-184888miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Sporadic communication error 1000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8K2 907 401 HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0006
Revision: 15H01---
Coding: 0114002C191F0A28
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TDI0118K2907401 001006
ROD: EV_ECM30TDI0118K2907401.rod
VCID: 6ADBDBB98DB6321A65-803E
5 Faults Found:
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [109] - Electrical Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 297500 km
Date: 2019.01.01
Time: 14:59:42
Engine speed: 927.50 /min
Normed load value: 53.7 %
Vehicle speed: 0 km/h
Coolant temperature: 4 °C
Intake air temperature: 2 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.540 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 927.5 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 13540 mV
Coolant temperature: 4.8 °C
Glow status-Bits 0-7: 00000000
Glow status-Bits 0-7: 10110000
Glw Plg r LVS Ps: 20.08 %
Intake air temperature: 3.0 °C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [109] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 297500 km
Date: 2019.01.01
Time: 14:59:42
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [109] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 297500 km
Date: 2019.01.01
Time: 14:59:42
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [109] - Signal too High (Rich)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 297502 km
Date: 2019.01.01
Time: 15:06:29
Engine speed: 1520.00 /min
Normed load value: 0.0 %
Vehicle speed: 56 km/h
Coolant temperature: 42 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.200 V
Crankshaft speed (RPM): 1520.0 /min
Vehicle speed: 57.34 km/h
Lambda probe heater activation: 40.22 %
LSU r O2 Adap: 0.05479
Oxygen signal calibration status-Bits 0-7: 00000000
Lambda probe diagnosis-Bits 0-7: 00000000
Lambda probe diagnosis-Bits 0-7: 00010000
Lambda probe temperature signal: 1009.2 mV
4862 - No Communications with Aux. Heater Control Module
U0166 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 297539 km
Date: 2019.01.01
Time: 16:58:51
Engine speed: 1191.50 /min
Normed load value: 9.0 %
Vehicle speed: 57 km/h
Coolant temperature: 74 °C
Intake air temperature: 6 °C
Voltage terminal 30: 14.240 V
Crankshaft speed (RPM): 1191.5 /min
Vehicle speed: 57.95 km/h
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 14240 mV
Bus Diag st Node 0-Bits 0-7: 00000000
Com ct Rx TO GW-Bits 0-7: 00000000
Cr C st Key 0-Bits 0-7: 00000000
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 A HW: 0B6 927 156
Component: 0B6 30 TDIRdW H04 0050
Revision: --H04---
Coding: 001001
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 346705C19FF2B4EA0F-8060
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 148500
VCID: 7BF5EEFDFA2CBB928E-802E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AE HW: 8K0 907 064 AE
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 050000
VCID: 73E5C6DDD27CF3D2D6-8026
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0208000041577014
3 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 03:11:06
03287 - Sensors for Contact with Door Handles
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 04:53:30
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 297543 km
Time Indication: 0
Date: 2019.01.01
Time: 17:21:18
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001122043
Coding: 08017825002400001000
VCID: 428B5319DD460A5A8D-8016
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 P HW: 4E0 035 729 A
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 331HV087527645
Coding: 0015002
Shop #: WSC 00000 000 00000
VCID: 46834F09316E367AA1-8012
Subsystem 1 - Part No: 8T0 919 609 C
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000124274
Subsystem 3 - Serial number: 0129.07.080000000100010605ÿ
Subsystem 4 - Serial number: 010605ÿ
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 22
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 03:16:04
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:09:10
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000110 10000000
Bin. Bits: 00000000 00000000
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0104.08.080667
Coding: 360A0000
VCID: 72EBC3D9AD66FADADD-8026
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 14
Reset counter: 237
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:25:41
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000098043
Coding: 2600D2914174AF010009000300005D5D4F1C638800010141000000
VCID: 306F09D163EA88CA6B-8064
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 060808 H13 0040
Serial number: SWFBIE 0000518
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10215938
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000608081827
2 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 16
Reset counter: 237
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 01:16:00
03395 - Control Module for High Beam Assistant
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:39:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBH8533902
VCID: 2A5B1BB98536F21AA5-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52830822007525
Coding: 310101
VCID: 3B752EFDBAAC7B92CE-806E
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 0079B9
Shop #: WSC 04508 001 1048576
VCID: 326B03D96DE6BADA1D-8066
1 Fault Found:
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 21
Reset counter: 22
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:26:57
Freeze Frame:
Temperature: 18.0°C
Voltage: 14.08 V
Hex Value: 0x0035
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD18914N
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C772DE1B7A27CAAC7-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME38334F3FR
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME3E31436FN
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME0803413C8
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME03062B3AD
Crash sensor for front airbag: driver side:
Serial number: 63732SME6F052322Y
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME7F053320Z
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HGT00019
Coding: 0000BE
VCID: 3E7327E9A9BE6EBAE9-806A
Component: E221 - MFL H02 0003
2 Faults Found:
02797 - Control Module for Directional Stabilization Assistance (J759)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 01:57:37
02795 - Steering Wheel Vibration Motor (V331)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 19
Reset counter: 21
Mileage: 1048574 km
Time Indication: 0
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 930 S HW: 8T0 920 930 S
Component: KOMBIINSTR. H14 0224
Revision: 00000000 Serial number: 9DD752Y78
Coding: 038F01004E000008010100
VCID: 46834F09F16E367AA1-8012
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:10:23
Address 18: Aux. Heat (J364) Labels: None
Part No SW: 8K0 265 105 A HW: 8K0 265 105 A
Component: Standheizung H07 0040
Revision: 11001001 Serial number: 20080702100211
Coding: 5D0000
VCID: 275DE28D5624CF72BA-8072
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0092
Revision: FB402044 Serial number: 4400F08726825A
Coding: 000303
VCID: 4A9B7B39E576D21A45-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18035133270708
3 Faults Found:
02849 - Control Module for Lane Change Assistance (J769)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:40:36
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 21
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 03:16:34
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 21
Mileage: 297539 km
Time Indication: 0
Date: 2019.01.01
Time: 16:58:51
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
VCID: 2B551EBD4ACCEB125E-807E
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001122003
Shop #: WSC 06325 123 12345
5 Faults Found:
03338 - Force Limit for Fore/Aft Seat Adjustment: Forwards
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:14:30
03330 - Motor for Fore/Aft Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 237
Mileage: 297550 km
Time Indication: 0
Date: 2019.01.02
Time: 18:41:53
03331 - Motor for Backrest Angle Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:15:15
03332 - Motor for Height Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:15:16
03333 - Motor for Cushion Angle Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 235
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 02:15:16
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333HW087601579
Shop #: WSC 00027 218 55245
VCID: 3B752EFD7AAC7B92CE-806E
Address 3C: Lane Change
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: ĠQ
Coding: 011C12225C002201
VCID: 7DF1E0E5E438B5A2B0-8028
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 237
Mileage: 297500 km
Time Indication: 0
Date: 2019.01.01
Time: 03:20:20
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113462285
Coding: 011A1EC000390585032000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Serial number: 0123456789ABCDEFGHIJ
1 Fault Found:
03124 - Terminal 30 - 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 21
Mileage: 297543 km
Time Indication: 0
Date: 2019.01.01
Time: 17:21:18
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814003825401
Coding: 010101
Shop #: WSC 12336 024 394758
VCID: 3F8D5AEDAEB467B2E2-806A
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:01:12
Freeze Frame:
Voltage: 9.60 V
Temperature: 36.0°C
Temperature: 41.0°C
Bin. Bits: 00000100
Bin. Bits: 00000000
Bin. Bits: 00000100
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 237
Mileage: 297549 km
Time Indication: 0
Date: 2019.01.02
Time: 18:10:54
Freeze Frame:
Voltage: 12.20 V
Temperature: 251.0°C
Temperature: 253.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1301
Coding: 011C12225000120102
Shop #: WSC 14107 000 1048576
VCID: 4FAD6A2D1E14F73212-801A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000196203
VCID: 31690CD568E081C264-8064
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000017
Shop #: WSC 06324 000 00000
VCID: 306F09D1A3EA88CA6B-8064
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336H1087587089
Coding: 0000001
VCID: 2E5317A9B9DE9E3A79-807A
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 A HW: 8K0 907 383 A
Component: Anhaenger H06 0040
Revision: 1A002002 Serial number: 00000113367829
Coding: 0100000000000000
3 Faults Found:
02566 - Trailer; Left Turn Signals (M62)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 294842 km
Time Indication: 0
Date: 2018.12.09
Time: 19:15:59
02563 - Trailer; Right Tail Lamps (M61)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 294842 km
Time Indication: 0
Date: 2018.12.09
Time: 19:16:00
02564 - Trailer; Left Tail Lamps (M60)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 294842 km
Time Indication: 0
Date: 2018.12.09
Time: 19:16:00
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J8791SV
Coding: 1030008
VCID: 377D32CD46845FF22A-8062
End-------------------------(Elapsed Time: 03:57)--------------------------
Address 18: Aux. Heat Labels: None
Control Module Part Number: 8K0 265 105 A HW: 8K0 265 105 A
Component and/or Version: Standheizung H07 0040
Software Coding: 5D0000
Work Shop Code: WSC 06325 000 00000
1 Fault Found:
01406 - No Flame
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 22
Mileage: 297550 km
Time Indication: 0
Date: 2019.01.02
Time: 19:04:16
Freeze Frame:
Temperature: 39.0°C
Temperature: 45.0°C
Voltage: 10.80 V
After-Run
Error Code: 210
Temperature: 6.0°C
Address 18: DTCs cleared
