CR41G
- Joined
- Jun 7, 2015
- Messages
- 171
- Reaction score
- 16
- Points
- 18
desided that its best that I make a one stop shop thread instead of keep posting random questions every 5 mins .
so starting from the beginning when I first got the a3 to present time and I will add to it as I go along aswell as ask the odd random question for good mesure ...
anyway
little back ground info ..02 audi a3 1.8 20v turbo sport ,aum engine code and ko3s turbo
i had owned it for no longer than 24 hours before engine management light came on , which turned out to be split and bodged up pcv pipes in which i replaced the damaged ones ..see pics below
after that lot was sorted i moved on from that and bought a forge 007p diver valve
next up was the s2000 air filter md so i purchased a 90mm to 70mm silicone reducer and riped out the air box and done the s2000 air filter mod.
desided the next mod would be a boost gauge but couldn't find a pillar pod for the a3 so after reading around on here i found some one had used a leon pod .. so i did the same , ordered 8 meters of silicone vac line from ram air , autogauge boost gauge and leon pillar pod .. the pod requires a bit of trimming to fit but i was rather happy with the way it looked after mocking it up
and finally finished the installation and got the gauge plumbed in and wired up
all was well for a month and then hit running problems again so set about removing throttle body and giving it a damn good clean which helped but didn't cure the problem ,,turned out the MAF was shagged so replaced that but still wasn't 100% .. so replaced the air intake temp sensor which sorted the issue.
next up was the split coolant plastic y pipe right next to expansion cap had desided it want to spring a leak .. i couldn't find the part in the uk on google search or ebay so called euro car parts and gsf who both told me it was a main dealer part only , so posted the issue up on here and got put into the direction of mike the parts man on here who sorted me out the part in lightning fast time and next day delivery .. top bloke!!
the part in question
also fitted and wired up my sub and amp and did the n249 valve bypass removing all the old crap and fitting nice new black silicone hose ... didn't get any pics just one of all the crap that i removed doing the bypass
next up was that i found my forge dv was sticking , so replaced it with the standard one and ordered a rebuild kit, which turned up a few days later.
so basically today i serviced the forge dv , in the kit you get a new piston which now has an o ring on the bottom to stop boost from leaking heres a pic of the new compared to old
inside the body of the dv the o rings where starting to perish and it was full of gunk and grime so removed all old o rings and gave the body a good clean with some brake cleanerto get it looking shiny new again , fitted new seals and greased the piston and rebuilt.
service kit
dv stripped
not goin to refit until ive done my next load of mods ...pcv delete and catch can install , silicone turbo inlet pipe and 5 piece silicone boost pipe kit.
that's me upto date for now but will continue to add to this as i continue and remember to take more pictures ha ha
anyway
service kit
dv stripped
