- Joined
- Apr 22, 2015
- Messages
- 721
- Reaction score
- 76
- Points
- 28
Is the Dash fed via Relay ?
Now you see it , now you don't , intermittent electrical [ supply] fault to dash ??
from cold ok no problems , runs fine
RUN Till HOT ...leave standing 30/50 mins
Problems set in
Power ON , Dash lamps flicker
on/off clears
starts ok, then stops , dash lights flicker / can extinguish .. Air con lights extinguish
IG On/OFF fault clears starts runs normally
The fault only occurs if the car is HOT and left to stand for any length of time
cold start >> run normal
Q Is there a relay that feeds the DASH & AIR_CON control panel 12v supply ??
Tnx _G
Problems set in
on/off clears
Tnx _G
