Could well be, couldn't say for sure. When pressing the clutch you're obviously taking the drive away from the wheels, hence any load, so it could be many things. Process of elimination unfortunately.
Again, when you press the clutch the RPM will drop off, so try different gears at certain RPM. With clutch pressed, just rev engine to RPM at which it happens and see if the vibration is there.
