If you purchase it directly from Pipewerx they will fit it for you. If not it connects to stock cat back, or Milltek cat back without issues. Had it on both. I went with decat, and felt the difference immediately after fitting.Great videos of the track days, What do you think to the pipe werx downpipe? I was looking at that plus their 200 cel sports cat? Did you have any fitment problems mating it to the standard cat back section?
How did you mount your camera at Oulton Park? When I last went they were really funny in the safety briefing about filming and how the cameras were mounted.
Thanks mate. It peaks to 2 bar (all my gauge can read. Will see what it holds at today.Happy days, solid work mate really happy for you. Just awesome arent they? I ran on Revo stage 2+ for a little while but couldnt get the boost control I wanted, most who stick with Revo 2+ (and you can) add in a boost controller, just something to look out for on the dyno. What do you see boost wise on VCDS? I was seeing 2.1 bar on the first upramp of boost even at B4.
Sorry dont want to be a smart *** here! but there is not any problem for a good calibrator this dayes to make ecu to adjustt stable boost up to 2bar and more on this ecu. If you know the wastgate pressure and linærity this no problem
Tell that to the tuners that say they can't.
I know those who can.
Yes you are right on that Alex. Some tuner looks like they have give up this ecu. I think that must be more to the will or the experince they have with this ecu maybe.
The run in June was with settings B8 T5 F6. Didn't have an uprated intercooler then either.are those figures on revo stage 2+ without adjusting the software?
great gains through rev range!! would love tte420 one day...
Wery nice car and great result on the dyno with TTE420 and revo st2+ software! More to come. mine makes 380Whp and 536Wnm with custom st3 software and RS4 injektors. I still find it strange how good the APR st2+ software and stock injektors works with the TTE420 turbo somtimes i must say!?
Dont tempt me...I would love a Syvecs, hmmm thinking. RS4 injectors, IE intake manifold and a Syvecs ECU, could be tasty.S3 injectors ahould get to around 400bhp maxed out,especially if the HPFP rail pressure is raised.
There are a few aftermarket S3 pattern injectors around which are said to cope with flow sufficient for over 500bhp,but I've never seen any results from any of these.
The subject of WHP to crank Bhp is more difficult with cars using a Hladex rather than a more convetional 4WD system,as the potential losses via the clutch are different,and many dynos are run in 2WD mode for various reasons.
The stock ECU still has a lot to offer for those who don't want the expense of an aftermarket ECU,but it would be very interesting to see what a Syvecs ECU would make from a TTE420.
I looked at these and found a set that flow 40% for £900, and another company with same flow increase for £1150. Quite expensive.
I did some research and found the FSI injectors from a Cobalt SS flow 30% more than the S3, same dimensions, but requires a harness adapter.
More info http://www.golfmk6.com/forums/showthread.php?t=43120&page=6
Yes i also belived earlier the max on the s3 injektors was 400hp. But this days we see people make 420-440 on the TTE420 and APR software. with 155-165bar rail pressure valve. R-tech also do this. APR Stg3 GTX turbo kit also uses stock S3 injektors on 160bar rail pressure. crasy but it looks like it works som how for them.
On thing to think abouth when it comes to injektors is that cold start cranking time in cold climates is bad with RS4 injektors. The smoke problems is not any problm this days with correct calibration but the cold start i dont think is possible to make really god.
Yes its not easy to use corect corection factor. i use 12% loss to be safe.
As far as the injectors go,up to a point increasing rail pressure will increase flow which is how this works.
I never had cold start issues with the RS4s but getting them to run cleanly was always a problem with the mapping I ran at the time.
The Syvecs uses 4port and 4direct injectors and is quite something after all the things before.
My bad, typing too quickly whilst playing Xbox. Yeah you are correct. TSI not FSI.I am sure you already know this, but the TSI injektors will not fit the FSI cylinder head.
Audi/VW TSI and Cobalt uses HDEV 5 style injektors and FSI uses HDEV 1 style.
Just because I'm curious. how cold is it in wintertimes in your area S3Alex?
http://www.bar-tek-tuning.com/lshop...si,21tf055,113,Tshowrub--1138132527.tfsi,.htm
Cheaper than I thought too!
Don't think they are multiport RS4 as they weren't around when I first used them.
You don't need any kind of aftermarket ECU to get more power. These aftermarket ECU's are nice for track and race cars due to their ease of calbration, but they are also painfully basic compared to the OEM ECU. The only reason people use them is when their tuner cannot properly calibrate the OEM ecu for such drastically changed hardware. The ability to run port injection as standard is nice though.
Rick
