The way I set up my Blackvue is normally with permanent power. The car very rarely sits for more than 12 hours, if it does then it is in the garage. The Blackvue only records if it detects movement, so say in the works car park. I have the minimum voltage set and maximum working time set to 36 hours.
After 12 hours in work, I have never had any problems and the camera is still always running without fail. For my permanent feed, I used the fuse outlet for the security alarm. The only time the car has sat for longer than 12 hours is in the shut garage, so the camera has only recorded me leaving and entering the garage so it has never caused a problem once again.
When parking in the airport, I have swapped the camera to switch live to record the car being driven by the P&R staff (I am 100% certain, the S3 will not be parked at the airport.. it will be safe in the garage anyway haha). For switched live I used the fuse outlet labelled something like drivers side cornering light, the first switched live supply I came across and works perfectly.
When using fuse taps, it is just a case of unplugging and plugging in the tap into a different socket, making it very easy to change between permanent and switched feeds rather than a true hardwired installation, which you wouldn't be able to change.
