Liber_A4_te
- Joined
- Dec 22, 2016
- Messages
- 25
- Reaction score
- 10
Hello Everyone
Hoping you can assist me with my troubles with the HVAC system on my Audi A4 SE 2.0 B8. I have hot air blowing out of the passenger side vents all the time, regardless of what temperature is selected on the heater display. Driver/Centre driver vents all ok. Actions taken so far are as follows :
* VCDS run and retrieved the below fault codes
* Basic Settings accessed and attempted to run calibration on channels 001,002. All retrieved ERROR.
VCDS Report
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
Component: KLIMA 3 ZONEN H05 0120
Revision: D0000000 Serial number: 0112.03.080130
Coding: 34040000
Shop #: WSC 06325 000 00000
VCID: 3C21CA149663E927469-8068
4 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
00711 - Left Footwell Flap Positioning Motor (V108)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Freeze Frame:
Voltage: 13.50 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 12228
Count: 11184
01809 - Actuating Motor for Temperature Flap; Left (V158)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 10000
Count: 0
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
Freeze Frame:
Voltage: 14.00 V
Temperature: 14.0°C
Temperature: 5.0°C
Count: 10000
Count: 5357
Any assistance would be great
Sent from my F8331 using Tapatalk
VCDS Report
Coding: 34040000
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Freeze Frame:
Voltage: 13.50 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 12228
Count: 11184
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 10000
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
Freeze Frame:
Voltage: 14.00 V
Temperature: 14.0°C
Temperature: 5.0°C
Count: 10000
Count: 5357
