Glossy black trim
BRISTOL86
Hi Guys
What's good to remove mild swirls from the glossy black exterior trim between the windows?
Cheers!
Pretty difficult to remove swirls from the gloss black trim, I've seen people manage it with machine polishing but is far from easy. You could try a cutting polish and trying by hand but not sure you'd get the results you're after
Ohhh I did it when I had the S3, I used either meguiars ultimate compound or poorboys black hole polish via a DA polisher.
Reactions: NevMan
Hi Guys
Cheers!
I've used q techniq nano polish seems to do the trick
Use my mini Flex Da works a treat with a slight cutting compound you'll not remove them by hand, also note because they are made of plastic heat build up is rapid same as the high gloss black plastic panels on the doors which require a bit skill to perfect via machine polisher so my advice would be buy a small dual action polisher £95 from in2detailing you'll use it on yer paint as well great tool
EB0D31E9D1674409FC6EE851AB2EFBE2
Reactions: DW81, Sandra, S32B and 1 other person
Use my mini Flex Da works a treat with a slight cutting compound you'll not remove them by hand, also note because they are made of plastic heat build up is rapid same as the high gloss black plastic panels on the doors which require a bit skill to perfect via machine polisher so my advice would be buy a small dual action polisher £95 from in2detailing you'll use it on yer paint as well great tool View attachment 177594
That's a handy tool for small bits, always been put off by the piano black interior for the obvious reason.
Thanks all much appreciated! :)
Reactions: Jassyo06 and NevMan
Reactions: Bristle Hound
Used the DA on the black gloss plastic trims for the first time last week with a sonax compound.
Excuse the pic not been cleaned since then.
IMG 20190330 092557
Got rid of minor swirling okay.
Reactions: NevMan and Jassyo06
753
