Hi folks,this is a bit of an un-educated guess but ive been having a fair few problems with my A3 TDi over the past year or so.
My main problem was with the car going into limp mode when doing anything over 50mph.Turned out the turbo was all clogged up so i decided just to get it changed.Ive also had the MAF replaced and some other boost pressure valve.
Since the turbo has been fitted ive felt the car hasnt been right.I was told that using fuel cleaner should prevent the turbo from clogging up again so ive used it every time ive filled up.
Now im still getting the limp mode but there seems so be a lot less boost as the days/weeks go on.When i start the engine aswell it sounds a lot louder than usual and i get a bit of juddering.
I was wondering if now ive been using the fuel cleaner could it be dislodging stuff and clogging up the fuel filter or does anyone think its anything else from what i have said?
Ive taken it back to the guy that done all the work and he says there are no fault codes coming up.
Im really at my wits end with this problem so any info or advice would be really appreciated.
