FBMFSW again
*bump*
Right guys its been a while but i am almost there with the bits for my retrofit the last thing i am struggling to acquire is the slipring for the steering wheel. as i have a B7 FBMFSW to go on my B6 car i am under the impression that the part i need is 4E0 953 541 B which is about £165 new. Now is this the only part number slipring that will do the job as i have seen quite a few 'A' versions going cheap but not sure what exactly the difference is. also seen a few 8E0 953 541 'C`s' and 'D`s' again are any of these compatible with the B7 wheel and its multifunctions??
Any advice welcome as i would like to try to avoid paying £165 if i can.
Surely gareth would be in big trouble doing these mods if a paying customer crashes and his airbag doesn't deploy. I'm sure the police and insurance companies would be interested to. I know you've done research Dave but i've recovered many unmodified cars from rta's and the unmodified factory fitted airbags haven't deployed. The only way you know it will work 100% is when you crash god forbid.
I've just retrofitted a TTS fbmfsw into my B6 all went well except the multi function buttons / rollers do not work. They light up dimly as soon as the ignition is switched on. Is there any way to check the buttons with a multimeter theres only 3 wires and 1 of them is ground. I tried to check them with measuring blocks in VCDS but they do not function. Here's the autoscan log from VCDS
Saturday,21,November,2009,15:52:49:63169
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E23A187741 Mileage: 159680km/99220miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00003
Shop #: WSC 63351
WAUZZZ8E23A187741 AUZ6Z0B0173883
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04255
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02042
Shop #: WSC 63351
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 981
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 01401
Shop #: WSC 00001
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H74 0650
Revision: 04S Serial number: AUZBZ7G0052604
Coding: 0301715
Shop #: WSC 32727 551 00000
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 07115
Shop #: WSC 63351
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301715
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00114
Shop #: WSC 63351
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005087273
Coding: 0011822
Shop #: WSC 00000 000 00000
End ---------------------------------------------------------------------
I've read through lots of steering wheel threads / posts and noticed a few other people had the same problem but never said if or how they fixed the problem. I did not change the steering control module to 8E0953549R as my car came with cruise control factory fitted and was told this module should be ok as long as it took the coding which it has. Even people who changed the module had the same problem. Any advice greatly received.
ive done the mod and my coding is
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02011
Shop #: WSC 00672
Coding: 02011
Shop #: WSC 00672
Do the lights in your multifunction switches dim when you adjust the dash lights?
All sorted now:) had to change the steering control module even though i had factory fitted cruise:(. Just can't get the mode button on the steering wheel to do anything everything else works including the voice control. I must say she is very polite when you swear at her:)
How have you coded the SCSM and the BT module?
Thanks for that Dave i'll try it but don't understand why it should be that as i have voice control. I did the sds hack on my RNS-e which works great. Looking at that link i messed up anyway 04042 looks obvious which i missed.
849
46
4K
4K
21
22
614
