Fault Codes Help
Isaa
Hi
Wondering if you guys could give me a hand with some faults that I've found.
The actual reason for me running a scan on my car was because for some reason my front passenger door no longer unlocks with the rest of the doors, it has to be opened from the inside.
This is what the scan brought up.
Thursday,22,January,2015,17:51:58:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 1719 25 42 44 46 52 56 62 72
VIN: WAUZZZ8PX8A006734 Mileage: 215450km/133874miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LS HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9182
Revision: --H07--- Serial number: AUX7Z0G4FNT112
Coding: 0000071
Shop #: WSC 06314 000 00000
VCID: 7BFFE9353AFE411
1 Fault Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 3
Mileage: 202115 km
Time Indication: 0
Date: 2014.03.14
Time: 18:03:01
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 11000000
Temperature: 15.3°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
VCID: 73EFC11512AE091
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047
Component: J255 Klima Man H07 0010
Shop #: WSC 00000 000 00000
VCID: EDDB576DF48A5F1
Address 09: Cent. Elect. Labels: 8P0-907-279-30-B.lbl
Part No SW: 8P0 907 279 J HW: 8P0 907 279 J
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007095197
Coding: 00880F01B0141000470000001600000000085A175C010000000000000000
Shop #: WSC 06314 123 08192
VCID: 448D52C90780FE9
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP0G04SUW
Coding: 0071612
VCID: 4B9F79F52ADE311
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000002
VCID: 78F5F6390BC86A9
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 951 G HW: 8P0 920 951 G
Component: KOMBIINSTR. VDO H20 0630
Revision: D0H20001 Serial number: 1244G001000132
Coding: 0004423
Shop #: WSC 00011 888 96745
VCID: 3973333D7042B31
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Mileage: 203455 km
Time Indication: 0
Date: 2014.05.11
Time: 17:22:41
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07522823C
Coding: E9807F060002022103
VCID: 30650E19A338729
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 200
Mileage: 161703 km
Time Indication: 0
Date: 2011.06.13
Time: 16:57:07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G4FNT112
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H02 0040
Coding: 0000688
VCID: 438F51D5028EF91
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 36693801415C5C9
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H10 0080
Coding: 1980202002186D0985054C9FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000688
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
Component: R Chorus2+ H15 0240
Revision: 00H15000 Serial number: AUZ1Z2G9182800
Coding: 0000221
VCID: 2B5F19758A1E111
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Mileage: 104526 km
Time Indication: 0
Date: 2009.09.24
Time: 13:15:38
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 41835BDD1892EB1
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428154D11D94F09
End ---------------------------------------------------------------------
Now it seems that the scan has produced more than one fault but as I am an amature when it comes to these sort of things I have no understanding of the aboth codeings. Would someone be able to translate the above codings as to what the actual faults are.
Any contributions are appreciated.
