Esc, hill assist faults!?
Austen Bickley
After getting into my car yesterday, faults for hill assist, esc, start stop have flashed up, and i also noticed my rear parking sensors do not work.
Scanned the car with vcds and some strange faults came up just showing things like 'missing message'.
Any ideas where to start? I'm at a complete loss!
Saturday,06,March,2021,13:13:47:35461
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ8V3EA197732 License Plate: SK15JZJ
Mileage: 93604km-58162mi Repair Order: esc faults
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F A9 BB BC
VIN: WAUZZZ8V3EA197732 Mileage: 93604km-58162miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1900322426010B2004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DA7F2A35D79C6B3E45-8028
1 Fault Found:
17178 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Mileage: 93598 km
Date: 2021.03.05
Time: 19:08:17
Engine RPM: 817.50 /min
Normed load value: 7.8 %
Vehicle speed: 0 km/h
Coolant temperature: 82 °C
Intake air temperature: 24 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 11.660 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 611640000008FD
Coding: 32F193A254292A73017E070341C5694CC92A5480E08296F6024100080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA3FCBB436DC883DA1-802E
2 Faults Found:
8210 - Databus
U1121 00 [137] - Missing Message
[FCAN: Allrad_03 message is not received]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 227
Mileage: 93598 km
Date: 2021.03.05
Time: 19:08:17
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 37 km
Date: 2015.01.27
Time: 10:31:25
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000315989
Coding: 03100014000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 3333149B2BBDC0C3421-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 51198927000000000001
No fault code found.
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011412602379
Coding: 07140A46C24122F503844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140426 041 0580
Serial number: 140430093812
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22592110
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Component: E1 - LDS MQB H05 0032
Serial number: 08 01 2014 00000577
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140913K1G
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029596244
Sunroof control module:
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO2885617B
Coding: 901E00
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 219
Mileage: 92405 km
Date: 2021.02.09
Time: 19:17:55
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831412702530
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 382923B732DB239B773-806C
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 227
Mileage: 93598 km
Date: 2021.03.05
Time: 19:08:17
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R06K8GI
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC36C7B534DB8032A1-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 705 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000E6A78BF0D
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 14
Component: SideSensor_Pf 001 0887
Serial number: 358670000006BA78BF0B
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 402 804 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502A51529DF5920C
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 402 804 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502A5157E9D2F0DV
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 404 14
Component: FrontSensor_D 001 6149
Serial number: 3556502A5157E9D0F2F-
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 404 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B5157E9D6314I
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 404 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B7157E9D4236M
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 504 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C7157E9D3D18P
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 06051408490341
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 094F967319B1EA13D8D-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 R HW: 8V0 920 970 R
Component: KOMBI H03 2220
Coding: 27AD08022A8046000101E800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001901415
Coding: 030100042B085A005B000268080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB48AB17F514A3B69-806A
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 19 04 2014 B0255678
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 1329123303
1 Fault Found:
131599 - Control Module for All Wheel Drive Clutch
U0114 00 [009] - No Communication
[Timeout Knoten 0x0F / 22 - Steuergerät für Allrad]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 227
Mileage: 93598 km
Date: 2021.03.05
Time: 19:08:18
Terminal 30 power supply: 11.5 V
Terminal 15: On
Address 22: AWD Labels: None
Part No SW: HW:
Serial number:
ASAM Dataset:
ROD: N/A
VCID: 045187473E93B77BABB-8050
No ASAM data for: "" (AU37)
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 25041406070732
Coding: 00518E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D94B576A0B6B5BCF3-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 35372A8325C9DEF36C5-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 24041404080762
Coding: 005186204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01AE000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7EA8365499EF3AC5-8020
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V0 035 020 J HW: 8V0 035 020
Component: MU-H-ND-EU H42 0404
Serial number: A305E0E7516362
Coding: 017303010000000021111102000A00002F00022701000100DE
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 323D119FD4A7C9CB497-8066
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 SL HW: -----------
Component: ECE 2021 --- 0189
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9EY200Z67
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000025021400020156
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 224
Mileage: 92405 km
Date: 2021.02.09
Time: 19:03:53
Voltage terminal 30: 11.8 V
System_Software_Versions_ Mgt-SW_VersMgtInfo: MDUA201/Front
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140404200593
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 26041401101695
Coding: 004186204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 42DD415F6407794BD97-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 16041401100243
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Gateway Installation List: 5Q0 907 530 Q
09-Cent. Elect. -- Status: OK 0000
Revision: --H09---
1 Fault Found:
17178 - Databus
Readiness: 1110 0001
1 Fault Found:
8210 - Databus
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Coding: 901E00
Coding: 0000050001
1 Fault Found:
13637426 - Databus
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A408
Generator:
1 Fault Found:
Part No SW: HW:
Serial number:
ASAM Dataset:
ROD: N/A
Coding: 8103
Data carrier:
1 Fault Found:
B201A 00 [009] - -
End----------(Elapsed Time: 01:35, VBatt start/end: 14.7V/14.6V)--------
JohnM100
Gold Supporter
Looks as though you ran the scan with the engine running.
Have you had battery problems - there are several low voltage warnings listed.
Do you have warning lights on the dash too?
If a battery issue, take it for a drive and most of these will sort themselves out. Then rerun a scan and clear the error codes to see what comes back.
Austen Bickley
Yeah there are warning lights for hill start assist, esc, and start stop on the dash.
Took it for a drive and no change, then I tried clearing faults and they come straight back.
I put a meter on the battery with engine running and its 14.6v - so alternator fine
Then when the engine had just been turned off, reads 12.7v
Soon as ignition turned on it drops to 12.2V and continues to drop, after 5 mins its at 11.9/12v.
Does this sound like the battery is on its way out? Wouldnt of thought a healthy battery would drop 0.5v immediately with ignition on?
Thanks for your help!
MarttiMat
What is your typical drive cycle? Do you do a lot of highway driving or more around town / short trips? The latter would put a bit more strain on the battery as it does not have as much time to charge back up after sitting. I assume you have had the battery changed before or is this the original? 11.5V will cause modules to act up and store faults / turn on warning lights.
JohnM100
Gold Supporter
From what you say, battery looks to be on its way out.
Is your car stock, or any post build mods?
Austen Bickley
Sorry for the late reply, I have now changed the battery, but it does not seem to of sorted the problem. However some days when i turn on the car the faults are not there? But if the cars turned on and off a few times they appear
MarttiMat
Did you code the battery to the car? The alternator profile will change once the car is told a new battery is installed. If yes to those you might have something deeper going on electrical wise.
Austen Bickley
Yeah i coded it via vcds, I have also noticed my 4wd has stopped working, and the awd module isnt communicating with vcds, however the faults did go away for a few days but have come back, im starting to think I may have a broken wiring loom somewhere?
MarttiMat
Yeah, sounds like something electrical is going on. Do you have an Autoscan? You could always try posting in the VCDS forums since you have the tool.
Peter Peter
I had hill hold assist fault , then Electronic Stability Control (ESC) fault and tyre pressure data fault.. After reconnecting batt. and driving for 2-3 minutes all gone..
Battery isn't charging for you maybe?
Austen Bickley
Update incase this ever happens to anyone else... my haldex controller was buggered. Which was giving me all theae faults along with parking sensors not working etc. All sorted now though
jrpsu88
This exact situation is no plaguing my car after a visit to the shop yesterday. You said it's all sorted now, what was the fix for the haldex controller?
Austen Bickley
If its just happened since your car was in the garage i doubt its the controller, more than likely something unplugged.
However if your controller is at fault, you have to either replace it (1k plus) or send it off to Matt at auto fault finder, he fixed mine same day and sent it back, fantastic service.
