Error after auto lights/rain retrofit
kpm278 Sep 14, 2018
  1. kpm278
    kpm278 Member
    Hi
    I get a malfunction on the dash after installing auto light switch and rain/ humidity sensor. Here is the error log.
    I scanned before setting RLFS (09 - Cent Elect = Byte 6 > Bit 0-1 = 02 Light Sensor (PR-8N6) installed) so hopefully that fault is resolved.
    Is anyone able to suggest why I get an error?
    looking at the optional equipment list the car has from factory:
    automatic dynamic headlight range control
    led rear lights
    headlight washers
    xenon plus headlights
    Thanks, Kris
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
    Component: BCM MQBAB H H18 0134
    Serial number: 01011419804312
    Coding: 07040A46C24320DD03844004B31C07A80000000000000000000000000000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_BCMCONTI 013000
    ROD: EV_BCMBOSCH_013.rod
    VCID: 0059830BAA895B77714-8054
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 140713 041 0580
    Serial number: 140716220904
    Coding: 0A47F7
    Light switch:
    Subsystem 2 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
    Component: E1 - LDS MQB H05 0032
    Serial number: 26 01 2016 00001031
    Sensor For Anti Theft Alarm System:
    Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY141681KG4
    Alarm horn:
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000030264090
    Relative Air Humidity Interior Sender:
    3 Faults Found:
    197644 - Control Circuit for Fuel Tank Flap
    B1263 01 [009] - Electrical Failure
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 62
    Reset counter: 94
    Mileage: 1048574 km
    Date: 2000.00.00
    Time: 00:00:00
    930056 - Light Switch
    B126A 29 [008] - Signal Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 153
    Mileage: 186792 km
    Date: 2018.09.14
    Time: 16:44:15
    939524 - No Communications with Humidity Sensor
    U10F5 00 [008] - -
    [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 1048574 km
    Date: 2000.00.00
    Time: 00:00:00
  2. Avatar
    Google AdSense Advertisement
  3. kpm278
    kpm278 Member
    I found some information posted by DJAlix and followed it as I have also fitted the AE switch:
    1. Light Switch in Position 0, Wiper Stalk in OFF Position and Ignition in 1st Position ONLY.
    2. All Doors Closed but NOT locked.
    3. Make sure that 09 - Cent Elect > Long Coding > Byte 2 > Bits 0-2 are set correctly: If you have High Beam Assist (Light Assist) you need to select 03 from the drop down. If you don't have HBA you need to select 02.
    4. You need to Enable 09 - Cent Elect > Long Coding > Byte 7 > Bit 5 (Light Switch with Assistance Driving Light (ADL) Installed).
    5. Once 2 and 3 have been completed log off and turn off the ignition and wait for 5 mins.
    6. Turn Ignition to 1st Position.
    7. Reconnect VCDS and perform an Autoscan.
    8. When complete select save.
    9. Once saved select Clear All DTCs.
    10. Once completed Untick Display Freeze Frame and run another Autoscan, then save.
    Here is the final autoscan. I haven't turned the lights on yet as I enabled ADL (which I don't think I have - step 4 above). I figure this is to combat the fact I fitted the AE switch, but I don't want to break anything thus will await advice.....
    Code:
    Friday,14,September,2018,18:38:03:42375
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    Data version: 20180518 DS287.2
    www.Ross-Tech.com
    VIN: WAUZZZ8V5FA038728   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V5FA038728   Mileage: 186792km-116067miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 7539
       Revision: 81H22---
       Coding: 02190012030501082000
       ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
       ROD: EV_ECM20TDI01104L906021AE.rod
       VCID: 77ABE8D7FF471CCF40E-8022
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
       Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
       Component: ESC           H31 0471
       Revision: 00000000    Serial number: 62004000002468
       Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4006100788608
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 45D7521FF52BBE5F022-8010
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
       Part No SW: 8V0 820 043 D    HW: 8V0 820 043 D
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000387850
       Coding: 03100104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
       ROD: EV_AirCondiFrontVaAU37X.rod
       VCID: 33331CC7ABBF30EFBC6-8066
       Relative humidity sensor in fresh air intake duct:
       Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 0319CD37000000000001
       Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
       Coding: 0A47F7
       Rain Light Recognition Sensor:
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 63282863
       Coding: 02006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Alarm horn:
       Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231420400990
       Coding: 0000050001
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       ROD: EV_EPHVA14AU3700000_002_AU37.rod
       VCID: 3B2334E783EFF8AF646-806E
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Component: AirbagVW20    011 0361
       Serial number: 003M2R07T4KS
       Coding: 98CCC0000C0000005C5400CA00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X_VW37.rod
       VCID: 4BC36427D34F482FD46-801E
       Side Sensor Driver Front:
       Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
       Component: SideSensor_Df  001 0887
       Serial number: 357670000003EAD0001Q
       Coding: 2D2D2D
       Side Sensor Passenger Front:
       Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
       Component: SideSensor_Pf  001 0887
       Serial number: 35867000000DDAD0001-
       Coding: 2D2D2D
       Side Sensor Driver Rear:
       Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502C515F3C34B23C
       Coding: 2D2D2D
       Side Sensor Passenger Rear:
       Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502C515F3C324166
       Coding: 2D2D2D
       Front Sensor Driver:
       Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
       Component: FrontSensor_D  001 6149
       Serial number: 35565029D1697520A136
       Coding: 2D2D2D
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502C11656B83C307
       Coding: 2D2D2D
       Pedestrian Protection Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_P  001 6149
       Serial number: 2296502C11656B8393CH
       Coding: 2D2D2D
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_C  001 6149
       Serial number: 23065029B1656B853287
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Component: Lenks. Modul  002 0110
       Revision: --------    Serial number: 17071408490481
       Coding: 8408
       ASAM Dataset: EV_SMLSKLOMQB 017001
       ROD: EV_SMLSKLOMQB_013_AU37.rod
       VCID: 0655951388AD75474B8-8052
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
       Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
       Component: KOMBI         H02 4291
       Coding: 278509002B8026000100E8001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009040
       ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
       VCID: 3FDB40F797F7E48F48E-806A
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002290549
       Coding: 030100040F0876005B000248080B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011_VW37.rod
       VCID: 42DD4903E4058967270-8016
       Alternator:
       Multi Function Steering Wheel Control Module:
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Component: E221 - MFL  H02 0014
       Serial number: 12 07 2014  D0038904
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 3110563903
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
       Component: TSG FS        020 0025
       Serial number: 14071403110089
       Coding: 00108E204001040000001002
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT.rod
       VCID: 40D9430BEA099B77314-8014
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 8103
       ASAM Dataset: EV_SteerAssisMQB 010031
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF460FE103927F3EA-8014
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
       Component: TSG BFS       020 0025
       Serial number: 12071404080092
       Coding: 001086204001040000001002
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT.rod
    Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
       Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
       Component: LWR-ECU       005 0080
       Revision: --------    Serial number: --------------
       Coding: 019C000001000000
       ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
       ROD: EV_HeadlRegulVWLWRMQB.rod
       VCID: 75B7E2DFE54B6EDF522-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    041 0420
       Serial number: A7F01907140514
       Coding: 01730301FF0A000021111101000A00002F0004460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       Data medium:
       Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
       Component:  ECE 2014  --- 0036
       Serial number: --------------------
       Display unit 1 for multimedia system:
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304V8J
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000007061400020173
    Address BB: Door Rear Drv (J388)       Labels:* None
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0025
       Serial number: 11071401100167
       Coding: 000086204001040000001002
       ASAM Dataset: EV_DCURearDriveMAXKLO 006003
       ROD: EV_DCURearDriveMAXCONT.rod
    Address BC: Door Rear Pass (J389)       Labels:* None
       Component: TSG HBFS      020 0025
       Serial number: 11071402090166
       ASAM Dataset: EV_DCURearPasseMAXKLO 006003
       ROD: EV_DCURearPasseMAXCONT.rod
    End----(Elapsed Time: 01:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  4. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,145
    638
    Can you explain how you get your scan into that little box bit , i have tried to do it ross tech way but never works , i av win 7
  5. kpm278
    kpm278 Member
    Use the code tags when posting:
    [code*] scan info [/code]
    Without the asterisk
  6. kpm278
    kpm278 Member
    I got impatient and turned the lights on, all working without fault code :)
    DJAlix info above was the key
    DJAlix likes this.
  7. ch1z64
    3,145
    638
    Cheers mate still over my head
  8. kpm278
    kpm278 Member
    when replying to a post, along the top you'll see formatting options B I U etc etc
    find the one that says insert, click on it, then click on code
