Hi guys. I have been experiencing some annoying rough/erratic idles on cold engine starts. RPMs are jumping between 400 and 1000 until the needle settles at 800 after 30-40sec (see video). Engine/exhaust sound like a tractor during these first seconds and engine seems to stall almost. This only happens when the engine is absolutely cold (early mornings mostly when I haven't been driving for at least 6-8 hours). There are no problems when the car is warm and I cannot tell any difference while driving (maybe less low end power but I might be imagining things).
This whole problem started 2 months after I bought the car (was bought Feb 2012 new). I bought it to the dealership the first time and they replaced the camshaft control solenoid and timing cover gasket under warranty. Problem persisted so I brought it back...they repeated the process as they said they probably ripped the gasket while installing...yay...
Problem persisted and I brought it back a third time demanding this problem to be fixed once and for all. They kept the car 3 weeks and had several (according to them) conference calls with Audi Germany and other "experts" to find the root of the problem. In the end they replaced the injectors, the fuel pump and "cleaned the whole engine bay" (their words). FINALLY....the car started normally. This was October/November 2012.
Now for the last two weeks the problem slowly came back, getting worse every day.
I am thinking dirty throttle body/Idle air controller that keeps coming back ??? Or maybe a vacuum leak that wasn't discovered. Or defect coolant sensor. I don't want to go back to Audi again atm. They kinda p*** me off at that dealership.
Already tried coil packs and spark plugs...no change with new ones. Cannot locate any boost leaks through VAG-COM. No fault codes present.
If I cannot locate the problem myself I might take it to my local APR tuner to have a go at it.
Maybe somebody is familiar with this problem? Oh yeah...the problem already occurred when the car was fully stock.
Cheers!
Cheers!
