Just an observation, but I've noticed a few times whenever the subject comes up that some people seem to get mixed up with "Hold Assist" and Hill Hold Assist" apparently believing them to be the same thing, when they are actually different in the way they operate.
Hill Hold Assist only activates when the car is facing uphill and briefly holds the brake on so that the car does not roll back before drive is engaged.
Hold Assist needs to be activated by pressing a button and operates every time the car comes to a stop. There will be a green light on the dashboard and rear brake lights will be illuminated.
The way I see it if you use Hold Assist(which I never do) then Hill Hold Assist becomes redundant.
That's a jolly good summary, except that Hold Assist doesn't actually operate every time the car comes to a stop by default; it only operates if you press the brake pedal firmly enough to engage it. It won't come on at all if you feather the brakes gently to a standstill.
For what it's worth, I use HA constantly. It's especially useful when you're towing. The only time it's a bit of a faff is when I'm backing out of our drive, because it's a downhill slope onto the road, and completely blind in one direction.
In that case, I have to go through very complicated sequence of operations to enable me to roll out into the road.
Get in. Check mascara in vanity mirror. Adjust genitals. Insert key. Mute MMI. Depress clutch and footbrake while selecting neutral (leaving it in gear when parked becomes a habit when you live in a hilly place...). Start engine. Lower driver's window and passenger side rear window. Disable Hold Assist. Release electronic handbrake. Select reverse. Release pressure on footbrake while keeping the clutch depressed. This allows the car to roll backwards. Rearward progress down the drive is controlled by the footbrake and steering, neither of which would function as required if the engine wasn't running. Hold Assist has to be disabled, otherwise every time I braked a bit harder to pause briefly and listen for passing cars, bicycles or pedestrians (which is the reason for having the windows down), the Hold Assist would engage again. Once safely out of the drive, I can raise the windows and use the controls normally. Twenty yards down the road I'll put my seatbelt on; it gets in the way something wicked if I put it on before rolling out of the drive.
Now I realise that you should put your seatbelt on before going anywhere on the basis that statistically speaking, the nearer home you are the more likely you are to have an accident.
I don't doubt that this is true, but I reckon the chances of me being involved in a potentially fatal RTA within twenty yards of the end of our drive are
extremely small (especially because it's impossible to speed down our road) so I'm prepared to throw caution to the winds in this particular instance.
