I see good reviews on the S-tronic but was wondering if they're any good on the manual? Are they specifically made to suite a DSG and manual or is it the same box for either?
I have used mine on my manual for two years and wouldn't remove it.
Now when I turn if off car feels too placid, kinda comes alive and feels more eager/responsive when using it. I use the middle setting, almost threw the motor in a hedge on the race setting in wet conditions but that was me sort of trying to provoke it and its response surprised me.
I am stage1 with it and still makes a chunk of difference in feel, if not necessarily performance.
Important to note that it doesn't change anything nor make the car do anything it wasn't designed to do, just affects the response from the throttle pedal......not that you will give a rats being stage2.
Once I went stage 2 I took the pedal box off. I had dtuk box and pedal box.
I have the forge short shifter, I have also done the clutch blender valve mod and clutch spring mod.
It now drives like a normal manual car should haha
What’s the result?There’s a washer in the bleeder block that can be removed.
What’s the result?
You don’t get the delay on the clutch when changing gear.
Do you mean the delay when changing up quickly and it takes a second for the power to come on. Also where did you set your forge shifter to? Thanks
Great stuff, I’ll get the shifter on and have a look at removing that valve.Yes that’s right pal.
I set mine to the minimum so the shift is very short.
