Drivers window won't go down
Benmk3
Hello all
On my b6 My drivers window doesn't go down , you can hear the motor working correctly but the window seems to be stuck ?
It's never been an issue until I pulled up at a drive through mcds
Is this a common fault with easy solution ?
Mike_B
Yea, avoid McDonald's. You'll probably find the lift cable mechanism to be the culprit. Avoid the eBay cheap ones I'm told. Common problem.
pauldazzle
Broken window regulator.
Replaced the regulator in mine last year. From memory it cost around £60 from GSF in Shrewsbury. Not a difficult job just make sure you study a few guides before tackling it, this will avoid undoing unnecessary bolts etc.
Benmk3
Cheers for you help guys I'll get the part ordered and make a start this weekend
AudiLeon
Well-Known Member
Your window could be related to my Mrs. They sound very similar.
