Hi guys.
I posted recently regarding my 04 3.2 DSG and the hesitation at 1600 - 2000. I had it into a local indy who couldnt find a software update but, found a P0011 - 008 - ****** Setpoint not Reached (Over-Advanced) - Intermittent fault code.
They think its a chain and I just wanted a bit of advice because thats a big job!
My VCDS scan and some of the blocks I found to check from previous posts are:
Monday,16,September,2019,12:27:28:31934
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
Address 01: Engine Labels: 022-906-032-BDB.lbl
Control Module Part Number: 022 906 032 CB HW: Bas isX 3
Component and/or Version: MOTRONIC ME7.1.1 5604
Software Coding: 0000178
Work Shop Code: WSC 06435 000 00000
VCID: 4D911F25D4ADA02722-8018
1 Fault Found:
16395 - Bank 1: Camshaft A (Intake)
1 Fault Found:
16825 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow
Readiness: 0010 1001
Address 01: DTCs cleared
Address 01: Engine (022 906 032 CB)
12:28:49 Group 208: Camshaft Adjustment Adaptation (Intake)
640 /min Engine Speed (G28)
124 Phase Position Intake Cam.
-4.0°KW Intake Cam. Offset
00100100 Intake Cam. Adaptation
12:28:49 Group 209: Camshaft Adjustment Adaptation (Exhaust)
82 Phase Position Exhaust Cam.
-8.0°KW Exhaust Cam. Offset
00100100 Exhaust Cam. Adaptation
12:28:49 Group 090: Camshaft Adjustment (Bank 1: Exhaust)
13.7 % Exhaust Camshaft Duty Cycle
0.0°KW Adjustment (specified)
0.5°KW Adjustment (actual)
12:38:19 Group 093: Camshaft Adjustment (Intake Adaptation)
12.8 % Engine Load
-4.0°KW Adaptation Bank 1
-8.0°KW Adaptation Bank 2
12:38:19 Group 094: Camshaft Adjustment (Intake)
2.5°KW Adjustment Bank 1 (act.)
Test OFF Result Bank 1
12:38:19 Group 095: Intake Manifold Change-Over
12.8 % Engine Load
77.0°C Coolant Temperature (G62)
IMC-V OFF Change-Over Status
Any help greatly appreciated.
www.Ross-Tech.com
1 Fault Found:
1 Fault Found:
12.8 % Engine Load
12.8 % Engine Load
