It was working fine until the outer handle started sticking now & then so i wd40'd it & grease the lock mech. Now the door trys to bounce open when closing it. Ive adjusted the catch on the B post but still the same
Ah well if the door handle is sticking then it might be not being in the correct position to catch the B pillar catch if that makes sense. Almost like it’s in a half open position.....
Fairly common Mk4 chassis issue... door latches worn and/or gummed up... I don't believe these are available nowadays but you can potentially grab a second hand one and try it or strip the one you have and clean/relube it as thats often sorts the issue
Mine do the same... need to get around to taking them apart one day
The WD40 done it! Put some on due to a freezing open in cold issue ,door closed perfectly before I put some on to lubricate it cleaned it off with electronics cleaner now back to normal.
