Changed coolant temp sensor and thermostat about a year and 10 months ago and have done 40,000 miles since then. Had an oil change couple of weeks ago and was told there is a light coolant leak. Noticed driving the last few days then it gets to 90 degrees then will drop a bit then come back to 90. Checked coolant and had dropped slightly below minimum so topped it up.
Is it really possible thermostat has gone again or more likely to be something else? What are the alternatives. Power is fine, all seems to run well apart from tyres not holding pressure perfectly. Want to avoid spending a lot on it being diagnosed!
