Hi,what are decent discs and pads for tt 3.2,also is 2 pots enough for spirited driving,or are there 4 pots from other model of audi that would fit mk1 tt.thanks charlie.
The 3.2 TT brakes are good. I respectfully suggest you make sure the brakes you have are in good order and working properly and take care to ensure the inside faces of all 4-brake discs are as good as the outside faces as in most cases they are not - just because the outside face looks good doesn't mean to say that the inside face is good!
Have to say, first thing I did to our 2003 3.2 TT (purchased at 58685 miles) was new OEM brake discs and pads all round - I'm paranoid about 'brakes' and for us a set of faultless brakes is mega important for "spirited driving" which we tend to do lots of!
I use 3.2 v6 discs on the front of my track TT. I bought a second hand brake kit off a user on here. Uses an adaptor kit to fit 8P RS3 /TTRS 4 pot Brembo calipers using the standard disc size. https://epytec.de/en/brake-system/a...s3-audi-tt-brake-caliper-adapter-brake-system
They do work very well on track with the Aston Martin OE pads. https://www.audi-sport.net/xf/threa...car-engine-rebuild.319422/page-4#post-3242662
The OE front discs are pricey as they have an alloy centre RS type disc. You can buy EBC or similar similar single part discs a lot cheaper ,I have these on my TT. They are directional as the OE items are.
MTEC also do some fancy 2 part discs that I may upgrade too at some point in the future. https://www.mtecbrakes.com/2-piece-...-golf-mk4-r32-334mm-front-discs-mtec7010.html
If it's just fast road driving then discs, some decent pads and fluid change would be the way to go.
Motul RBF600 is what I use in my TT. The 3.2 v6 TT is a lardy car and the weight certainly doesn't help. Remove 15Kg straight off by ditching the weight attached to the rear bumper mounts on the passenger side.
