Andrei1987
- Joined
- Aug 16, 2016
- Messages
- 42
- Reaction score
- 0
- Points
- 6
hy there recently bought an 2006 audi a6 c6 f4, 3.0 gasoline, i had a list of issues:
- In the morning when i start the engine (it starts good), but the motor will not run smooth (it variates with 50 +/- 50 rpm), after about 1 minute the motor runs smooth again, i see that the cooling liquid is below minim (i think it losses liquid with no liquid mark above the car, it has white smoke in the night, but the oil looks good and the level of the oil hasn t rise (don t know if it has a blown gasket). What is the correct injector timing on this motor?
- i had problem with 1 parking sensor, it will work if i buy a used one, it has to be the from the same place (rear mid lef, rear mid right) ?
- i have a bad abs module (if shows esp, abs and parking brake light), don t know if the owner had change it, but the screws looks like as if it was change or been took off, how i know if the module is bad or if i had a good module who needs the correct coding?
Thank you
Thank you
