  2. Dismiss Notice
Balance shaft delete kit
Dazza124 Aug 10, 2020
  1. Dazza124
    Dazza124 Registered User
    17
    Anyone done this as I have was running spot on but then oil pressure light on check pressure approx 1 bar on tick over up to 5.5 bar when revved the light only comes on when engine is warm and slowing down revs get to about 2k but accelerate and it goes out again
  2. Avatar
    snack-media
    Advertisement
  3. Jon13s
    Jon13s Registered User
    147
    65
    I've got one on mine. It come with a pressure relief valve etc from KMB.
    Although it provides enough pressure I'm lead to believe it triggers the light as it does not supply what is expected.
    I think on mine they've dipped into the base calibration to change the parameters whilst its having its stage 3 mapping, I can't confirm as the car isn't back yet.
    Seems to be a common thing in the USA.
    How long has it been running ok for?
    Sent from my SM-G965F using Tapatalk
  4. Dazza124
    17
    Since Jan I've got the relief valve also was given a part number to fit it has a lower reading flow 0.6 bar before triggering oil light it's a lot better but still annoying I've been trying a 0.4-6 bar ok on tick over soon as you throttle bingo it's on again I'm thinking of buying an original 1 from audi and getting my local vag guy to alter the settings
  5. tr7
    tr7 Registered User
    286
    80
    Delete kit as in going back to 1.9TDI oil pump?
  6. Gazwould
    Gazwould Registered User
    7,495
    3,032
    Don't delete Lanchester twin balancer shafts they do a job .
  7. tr7
    tr7 Registered User
    286
    80
    Works well enough in the BKD with none
  8. Gazwould
    7,495
    3,032
    Sit me in any 4 pot derv and I'll tell you if it's got them or not...
  9. Dazza124
    17
    Can the be reconditioned as I still have mine in my workshop
  10. Dazza124
    17
    What engine oil you using
  11. Jon13s
    147
    65
    5w40 quantum synthetic.
  12. Avatar
    snack-media
    Advertisement
  13. Gazwould
    7,495
    3,032
    The lesser..
  14. Dazza124
    17
    Was running 5/30 tried 5/40 see if it helped but to no avail was thinking of running a gauge inside the car to see what it's doing and bypassing the oil warning light
