I'm pretty sure the headlight switch is CAN based so there will only be 4 wires to it. CAN+, CAN-, power and earth. all the actual switching happens in the light control unit.
For the benefit of the OP RLS= Rain Light Sensor .As previous post says the switches on these cars are CAN based so usually on have 4 wires to them and communicate with the Central electrics module with CAN protocol.
I fitted a aftermarket module to my Passat that gave it coming home/ leaving light functionality I presume you are trying to fit something like this.
All the lighting is powered from the Central Electrics module and TBH it would be quite easy to blow something in the module by powering the lights from an external source to bring them on when they should be off. They are not all just driven by a relay.
