Honestly I cannot imagine 0.1mm making any particular difference.There will be a tolerance on the centre bore diameter and the spigot diameter.
They will never be the same as it would be too easy to get a build up of corrosion and then it would be difficult to make the wheel fit
The Centre bore is there purely to locate the wheel centrally, It's not to carry any load the bolts do that.
If it was load carrying then most spigot rings wouldn't be made from plastic.
As long as all the bolts are nipped up before the weight is put on the wheel there wouldn''t be an issue and the wheel would be centred.
Most vibration issues people get are usually due to flat spots on alloys due to pot holes / poor quality or tyre issues.
