Got abs and esp lights on in my A4 b7 8e . Scanned car and changed sensor , now light is on almost straight away when driving . Car failed mot over this and need to get it sorted ! Please help
Friday,03,August,2018,18:41:33:42103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WAUZZZ8E45A463260 License Plate: FE55ZPS
Mileage: 246860km-153391mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E45A463260 Mileage: 246860km-153391miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00502 210 91521
VCID: 75E466B11C6541EC07-8020
6 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 000 - Short to Plus
Freeze Frame:
RPM: 1722 /min
Torque: 90.0 Nm
Speed: 86.0 km/h
Load: 26.3 %
Voltage: 14.14 V
Bin. Bits: 00101000
Torque: 244.0 Nm
Torque: 109.8 Nm
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101001
Torque: 158.6 Nm
Bin. Bits: 0 01 0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 264671FD91437A747E-8072
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x00FF
Hex Value: 0xFF94
Hex Value: 0x00FF
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1004
Hex Value: 0x4212
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6BD040C91921871CE1-5120
3 Faults Found:
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
30-00 - Open or Short to Plus
09-00 - Adaptation Limit Surpassed
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 K
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3A7EB58D26FBEE942A-4AE6
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001N9J/
Coding: 0033622
VCID: 3B70B0897AC1D79C31-806E
Subsystem 1 - Serial number: 6332DRB40120CC0AK
Subsystem 2 - Serial number: 6342DRB4012091A3A
Subsystem 3 - Serial number: 6352ARB4003FF680T
Subsystem 4 - Serial number: 6362ARB4003FF6AE3
Subsystem 5 - Serial number: 63729RB4003FD5A5Y
Subsystem 6 - Serial number: 63829RB4003F9ABD2
5 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 229
Reset counter: 99
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 37
Reset counter: 99
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 99
Time Indication: 0
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 66
Reset counter: 99
Time Indication: 0
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 05042
Shop #: WSC 00000
VCID: 418CC2614B2DBD4C6B-4B00
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006441
Shop #: WSC 00046 412 81920
VCID: 397CAA8173FDE58C23-5120
3 Faults Found:
01314 - Engine Control Module
01321 - Control Module for Airbags (J234)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 397CAA8173FDE58C23-513C
3 Faults Found:
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 08187
Shop #: WSC 06325
VCID: 7DF47E91775519AC4F-4B00
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
3 Faults Found:
01134 - Alarm Horn (H12)
00962 - Alarm via. Tilt Sensor
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0410
Coding: 01205
Shop #: WSC 00256
VCID: 316C92A1FB8D2DCC9B-5072
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
Component: Parkhilfe 4-Kan H06 0020
Revision: 00H06000 Serial number: 00067802030435
Coding: 0000114
Shop #: WSC 131071 1023 2097151
VCID: 2F6894D9BDB93B3C8D-513C
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
01543 - Parking Aid Warning Chime (H15)
End-------------------------(Elapsed Time: 06:34)--------------------------
www.Ross-Tech.com
67 69 75 76 77
Coding: 0000072
6 Faults Found:
Freeze Frame:
RPM: 1722 /min
Torque: 90.0 Nm
Speed: 86.0 km/h
Load: 26.3 %
Voltage: 14.14 V
Bin. Bits: 00101000
Torque: 244.0 Nm
Torque: 109.8 Nm
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 819 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 882 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101001
Torque: 158.6 Nm
Bin. Bits: 0 01 0
Coding: 0004401
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x00FF
Hex Value: 0xFF94
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1004
Hex Value: 0x4212
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Coding: 00000
Shop #: WSC 00000
3 Faults Found:
Coding: 10001
Shop #: WSC 06325
Coding: 0033622
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 37
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 66
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Coding: 05042
Shop #: WSC 00000
1 Fault Found:
Coding: 0006441
3 Faults Found:
Coding: 0006441
3 Faults Found:
Coding: 08187
Shop #: WSC 06325
3 Faults Found:
35-00 - -
00956 - Key 2
Coding: 01205
Shop #: WSC 00256
1 Fault Found:
Coding: 0000114
2 Faults Found:
