Go into your vcds ( fo auto scan first ) save it . Then find your ecu module and copy the long code in it the if i mind you should be able to paste underneath the long coding and hit do it and then if accepted it will say coding accepted . Come out off vcds and remove key ftom ignition thrn give it a cpl mins and go back in and autoscan again
I cant find any code for the ecm in the autoscan. I have included a copy of the scan here in the hope someone can offer any further advice.
Is there a relay for the engine control module, if so, does any one know where it is on the A3? I have accessed the ecm to check the multiplug but all seems ok there. I haven't checked for power to the ecm as I don't know which wires to check.
Tuesday,19,May,2020,15:36:45:39370
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8P15A082208 License Plate: KR54NLC
Mileage: 302440km-187927mi Repair Order:
Chassis Type: 8P (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8P15A082208 Mileage: 302440km-187927miles
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7B0B1875C6539ADB-806E
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH13 0150
Revision: 115714 Serial number: 8P0820043D
Shop #: WSC 06314 000 00000
VCID: 2D513044B488F4224E-8078
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 302442 km
Time Indication: 0
Date: 2020.04.14
Time: 00:03:29
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 302442 km
Time Indication: 0
Date: 2020.04.14
Time: 00:03:29
Freeze Frame:
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011603
VCID: 438576FC020C125288-8016
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 306F2930A3BA99CA65-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 2249DD04000226
Coding: 0004413
Shop #: WSC 00444 210 87173
VCID: 36631F2841DEB7FA3F-8062
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1628244
Coding: 0001001
VCID: 326B2338ADB6ABDA13-8066
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 302442 km
Time Indication: 0
Date: 2020.04.12
Time: 01:20:05
Freeze Frame:
Bin. Bits: 10000
End-------------------------(Elapsed Time: 04:10)--------------------------
