Can someone run me through the process of changing the springs on a 1999 S3. Is there any special tools required and has anyone come across any problems.
You will have to remove the front struts, and use spring clamps. The rears are a lot easier just need to remove the lower bolts on the dampers and the springs will lift out. A good couple of hours work and would advise you get some assistance.
