my new a3 1998 18t problem trying to fit a set of clocks
mk1kid
west mids
basically i won a set of clocks from fleabay as my old 1s the pixels were all broken up i fitted the new clocks today and they all work fine just now the car will start for a second then cut out the orange light constantly flashes i think its the immobiliser light but im stuck what to do any help will be gratefull thank you will get some pics up of my audi as im new to the forum
You need to find someone that can retrieve the SKC code if you haven't got it already and then get your keys coded to the new clocks. I'm sure a search will turn up something...
^^ yup as said above you need to find someone to pull the SKC with VAG Tacho from your "new" clocks its a special 4 digit code that you need to login to the dash with vagcom to code to the ECU and the keys.
