funny boost
malcolm30029085
having trouble with my boost, if my s3 is driven fast (foot flat to the floor through the gears ) the boost spikes right up 2 bout 14 psi and holds bout 10 ish. but if driven normaly ie on the motorway, and then i go to accelerate the boost struggles to build up and barely reaches 8-9psi.also as the boost gauge is climbing it seams to be fluxtuating up and down, could this be the dv not holding the pressure??
its not had a re-map,also got new n75(j), and checked for leaks!!
the boost gauge to pluged into the top of the dv, maybe i should try the standard n75, how can i test the dv??
My friend had boost flux problems with his j valve, he adjusted the screw on the valve which sorted it (after some trial and error).
He was boosting about 22psi/holding 20psi tho on mapped software.
On top of the valve there is a hole machined out to access a flat screw (T fitting on the bottom) this adjusts the valves internal spring tension. Pretty sure there are some threads out there on it, i haven't had any experiance myself but it could be worth a shot?
Also try changing where you plumbed your gauge into, don't think its 100% when using the dv vacuum pipe.
T piece from the fuel regulator, I've never had a problem with it.
