PanamaS3
@PanamaS3 Sorry to jump in randomly but I was wondering what you think of the DV+ in combination with a DSG? I've only ever used them in manual cars and am wondering when it decides to dump to atmosphere really; anything between shifts with the paddles at full throttle or only on throttle release?
Do you think the Forge BOV you plan on getting will be much different than your current one?
Hey no worries Soul....I'm learning as I go along here, so here's my basic understanding:
I assume you mean upgrading the TCU software on your DSG in conjunction with upgrading the diverter valve.
Firstly, I think you should only do the TCU software upgrade in conjunction with a Stage 1 tune.
Now regarding the diverter valves. My limited, and very brief, technical understanding of blow-off/dump valves (atmospheric) is that the intake charge pressure built up is released to the atmosphere (with some noise) when you lift off the throttle instead of recirculating that air (with very little noise) into the intake track.
On our car, neither will cause any more or less "turbo lag" or increased/decreased performance. Both are good.
The DV+ (from GFB) that I have is almost silent and a superior diverter valve than stock. I felt better throttle response with it.
The Forge atmospheric valve was recommended to me as it sounds great (not "chavvy" I hope) and its mechanically not electronically operated, which means less (hopefully) to go wrong....and it will "dump" to atmosphere as follows:
When the throttle plate is open, the air pressure on both sides of the piston in the blow-off valve is equal and the spring keeps the piston down.
When the throttle is closed, a vacuum forms in the manifold. This in combination with the pressurized air from the turbocharger moves the piston in the valve up, releasing the pressure by recirculation or into the atmosphere.
Hope that answers your question.
