you release the colum adjuster and pull wheel out & down. Then the bit of trim directly below the cluster pulls out towards you, this will reveal 2 bolts to be removed. After removing these you will have to wiggle it out & release the connector at the back.
I reckon all you will have to adjust is the time, a short drive should put the other lights out. Recoding is only needed done if you change the cluster, then you will need to reset steering moduless & brakes etc.
