ok my cars parked up and been locked with the key fob, but everynow and again the hazards keep flashing constantly for a period of time even tho the car hasnt been touched, but there is no siren going off? help
sounds like your alarm siren has been disconnected. I had this done to mine as i had a problem with my door lock electrics. the car still thinks one of the doors are open, so when you lock it with the fob, it arms the alarm. but the supposedly open door sets off the alarm.
try and get the alarm to sound, if it does, then i am wrong. haha. but this is the problem i had with the same symptoms
you just need to find out where it has been disconnected and reconnect it. if you search the forum, im sure you will find the answer. however, if you fix the alarm but not the cause of it going off, you could be in for some sleepless nights
the switches in the photo are for two things....interior light and the dash display. if the one for the dash is broke, then it will not show the door as being clossed when it is. if the other is broken, the interior light will flash when the ignition is on or when the car is locked. i just worked out over time that it was the passenger side that was my problem. sometimes its cured by a swift slam, sometimes not and its a royal pain in the ***.
