Thinking of running 10mm spacers on the rear's . Would i have to buy longer bolt's with these, if so what size ???. AMD will supply the spacers at a good price ..
I would say yes you need longer bolts. I believe they are M14 x1.5 pitch and obviously 10mm longer than your stock ones. AMD should be able to supply. How much are the spacers from AMD if you don't mind me asking and are they hub centric?
That's presumably per pair, which is about the norm. If you search on ebay you can get them slightly cheaper but there's not alot in it.
Try ESP Engineering, they fabricate hubcentrics any thickness you want, and sell the longer bolts to suit.
Bolts (5 x longer ones per wheel) will be circa £20 a set. If you want locking wheel bolt/nut however, a set of 4 will be another £20 odd quid, so a complete set of bolts including lockers will be c£40 + P&P.
Definitely go ally, due to the weight mentioned above. Makes a difference. And yes you will need proper length bolts to suit whatever sized spacer you use.
Also I believe if you have OEM wheels you need a different 'seat' for the head to the bolt, than those for replica wheels...
