Links to A4/S4/B5 compatible Ebay finds and classified. FOR SALE/WANTED/ BREAKING
How quick are you needing the handles? Im going to be changing my door cards over soon so I would have the handles from the old ones.
Yeah that's fine, they've been ratting for the last year, a few more weeks wont hurt,lol
Hi all,
I am slowly starting to break my track car A4 1.8TQS this weekend and the following parts are on the car.
Suspension will be taken off last as I don't want to have it sitting on driveway without wheels for too long.
All big parts will be collection only from Leicestershire or I can possibly meet down south once a week.
I will be adding pictures as soon as they come off the car. I will not be taking payment for any parts until they are off the car so that I
can inspect each part before selling. All smaller parts + postage if can't be collected. All ono.
Suspension & chassis:
- H&R monotube coilovers with around 2k miles on them. Bought new at @ £930. Asking £550 posted. (these will fit S4 but front might be too soft).
- Full set of new Meyle control arms and used lighter B6 aluminium uprights fitted at the same time as coilovers. £300
- Rear control arms with recently fitted new bushes (Meyle & Lemforder) – two trackdays old £250
- Rear hubs with new bearings £50 for pair.
- 034 Motorsport (motorsport line) engine mounts. One trackday old £170
- 034 Motorsport Density Line gearbox mounts to fit 1.8T. One trackday old £60.
- ECS tuning snub mount for 1.8T. One trackday old. £25 posted.
- ECS tuning diff mount. Barely any miles covered. £100
- 034Motorsport prop centre bearing support. Still new. Never fitted. £70
- H&R 15mm spacers with bolts £60
- H&R 12mm spacers with bolts £60
Brakes:
- Front Brembo 6 pot kit with yellow 18Z calipers refurbed before I fitted them. All new valves, connecting pipes and new seal on one of the pistons. One helicoil.
MTEC discs, yellow Hel braided lines and yellowstuff pads. Might need a bit of cleanup as the red hot pads on track left a lot of dust in paint.
Fitting bolts were made by myself to get correct length as the ones bought from US were too short. Will also chuck the shorter ones in if someone wants.
£750 for the set or £800 with a new set of yellowstuff pads which I haven't fitted.
- Rear 300mm brake upgrade with S4 calipers bought new few months ago, painted yellow. 034 motorsport adaptors and yellow HEL braided lines.
Mtec discs. £250 or £280 with new yellowstuff pads.
Engine, box, ecu and exhaust:
- Non resonated Milltek cat back exhaust to fit 1.8T Bought new last year from AwesomeGti £350
- Large front mount intercooler with piping, (wellycooler) to fit 1.8T 3” inlet/outlet. £100
- Engine wiring with ICM delete for newer style coil packs (2.0T) £50
- AGU 1.8T flashable engine ECU £30
- DBW ME7.5 conversion from a passat to fit AEB/AJL engine. £250
- S4 Propshaft (facelift car) £60
- 1.8T Engine AJL code with 150k miles with rocker cover powder coated yellow and seal replaced. Cambelt, water pump, alternator belt and tensioner changed at 145k miles £300
- 5 speed gearbox and diff. Both covered 100k miles. £250 for set.
- Front panel with fully working radiator £40 (1.8T)
Interior:
- Double din cage. £50
- Two Sparco Pro2000 bucket seats with Sabelt 6 point harnesses. Drivers side seat has two small rips on side bolster from getting in and out. £400
- Sparco B5 seat frames (facelift) with side mounts on. £100
- Podi steering column mount £20
- Zilla aluminium gear knob with 5 speed quick shift £60
- 1.8T TQS clocks with fully working DIS. Blacked out air bag light (can be removed). £50
- Bose amplifier from a saloon facelift. £30
Exterior:
- Rear S4 bumper £120
- S4 side skirts £80 - these are fitted to A4 so the mounts on end are snapped off and one has a small crack on edge.
Also, both are riveted to the floor from underneath so will have holes. All easily fixable with a bit of fiberglass.
- Fiberglass front bumper with quick release. Could do with some fiberglass work to make it better finished. £60
- Factory fitted facelift Xenon headlights with new bulbs fitted last year £120
- S4 B5 lower door trim. Only the 4 large bits. All in nogaro. One with snapped bolt inside (one that is screwed through the door) £85
- Rear lights with silver bottom trim £40 for set.
- Passenger side rear light with nogaro bottom trim £25
Slepy have you got your ABS module still?
Sent from my SM-G920F using Tapatalk
Yes I do
Reactions: EvilSnow
How much is that going for
I have no idea. PM me :blink:
I'm after a light/indicator/cruise control stalk for my B5 1.9tdi. It's a 2000 model. Think the part number is 4D0953513M.
Anyone have one laying around??
Cheers.
I have one bought in error new (1 month ago)
Reason for sale I don't have cruise control and this stalk does £15 plus postage
Now removed
Front bumper :
Xenon headlights:
Intercooler:
A4 tie rod and end meyle hd range
Brand new and never got round to fitting to my B6
£30 plus p&p
IMG 1095
What are my 17" 8J ET35 boleros worth ?? all centre caps are present but have been bonded to the clips, could do with a refurb ??
I might be interested in your Boleros depending on price and where you are located
Does anyone have any genuine floor mats or alternatively where could I find some to fit an A4 B5 TQS?
Hi all,
Brakes:
Interior:
Exterior:
2DIN, Front bumper, Gauge and podi, intercooler sold.
Diff mount, snub mount and prop bearing now sold.
Engine mounts, gearbox mounts, milltek exhaust now off the car.
Also dug out the agu ecu and s4 maf.
Guys, I snapped a stud on my exhaust manifold where the EGR sits. Does anyone have a 1.9tdi AFN/AVG exhaust manifold kicking around?
Cheers.
Brand new Kufatec Cruise control loom and a used genuine cruise stalk to retrofit cruise into your B5 DBW car. Bought to fit my purple shed but selling the car now.
£40 posted.
Dan
For sale is my complete set of Brembo 18Z upgrade.
Consists of:
- 2x Brembo 18Z calipers. Had the bleeders, connecting pipes and mounting kit replaced before I fitted them on my car. One helicoil. I've used them on my track car for 2 years without any issues. Calipers could do with a cleanup/paint.
- 2x ML55AMG discs with drilled centres to fit audi hubs
- 2x yellow braided hel hoses
- 4x mounting bolts
- yellow pads with 5mm left on each side
I'm asking £700 for all, or £750 with another set of new yellowstuff pads. ONO
Collection in Leicester or I can meet down south once a week.
My full front suspension with B6 alu uprights and all control arms that covered under 2k miles are now for sale.
I bought this a few months ago
Eliminator Gt28rs turbo (used ) new 3 inch inlet for sale new 3inch decat from Atp fits standard manifold
https://www.ebay.de/ulk/itm/152020307485
and this from atp
http://www.atpturbo.com/mm5/merchan...duct_Code=ATP-VVW-138&Category_Code=AUDIVW-DP
And a 3 inch inlet for the turbo brand new £25
The down pipe is new and its original packaging (£200 paid with shipping and taxes ) 3 inch all the way
Fitted and driven for about 150 miles only selling due to upgrade
Turbo still on car connected to stock catalytic converter
Selling as a package turbo, downpipe , inlet £700 delivered
I've got pretty much only few bits left from my car. Will take decent offers on gearbox, diff and ajl head as could do with more space in the garage. Also have all the ancillaries on the engine like turbo, alternator, etc.
Ko4-064 turbo
162417116902
BBT zinc adapter plate for the turbo to fit 1.8 heads
162417118949
So I've come to the realisation that my tqs will most likely never emerge from the garage again, so I'm looking to sell it so thought I'd offer it up here first. I've owned this since 2010 and put about 40000 miles on it, only 2 breakdowns - 1st was the clutch & dmf, 2nd was a radiator hose.
Black 1999 TQS
Circa 150k miles (been garaged since June so can't remember exactly)
I'll start with the bad bits first!
Paint - presentable from a distance, but it has had a poor re spray at one point in its life. I was contemplating a respray or wrap.
Near side rear wheel bearing is shot
Wheels are rough, tyres are ****.
DIS is pixelated so needs replacing
Car is on a SORN.
Hopefully that is all the negative aspects.
Factory recaros, armrest and auto dimming rear mirror.
Has full genuine RS4 piano black trim
Has facelift S4 front bumper fitted (original available)
Double din
Has heated seat climate panel and kufatec retrofit loom, but the seats are not heated.
Fiscontrol V2 has been fitted, but due to the DIS, has not been configured.
Have Facelift S4 rear bumper and sideskirts, but are not fitted as a mixture of santorin and nogaro
Have rear refresh kit from allgermanparts that needs fitting along with the rear eibach springs (perfect for when the bearing gets replaced)
Have a set of oem xenons with ballast and bulbs ( untested ) but currently has standard halogens fitted.
Has Tatty B5 S4 Avus alloys fitted, but have 6 standard boleros too (also tatty)
Have both isofix brackets bolts and guides, but not fitted
Car is located in addlestone Surrey.
I really don't want to break it, but if I can't sell it I will break it, I'm sure it is against the rules but I'm not sure what to price it at? I would prefer it to go complete.
I need an S4 b5 front bumper and a off side front wing.
