Anybody ever changed an air con pipe before?
dieselfitter251
Blow ma own trumpet?
High 'C's
I've all the bits, (well pipe here hopefully for the weekend). The system is currently empty so no worries of nasty gas, just wondering if anybody knows what's involved.
Ta guys.
They can be very tight - the threads corrode (soft aluminium) and can get damaged trying to undo them.
If any of these pipes are those that go into the condenser, be careful - it's all too easy to twist the ends off, rather than undo the unions, if you're not careful!
you will be very lucky to remove and replace without causing damage, last owner of mine managed to wreck threads on condensor so i ended up buying a complete pipe, condensor and dryer that had been removed without being disconnected and fit them as one peice
Oh no...!
I took all mine out and binned them... apart from the front condenser/radiator. They were all in tip-top condition too.
Long story why I removed it all though!
Ok. Going by my track record with stinky I'll be bathing these joint in stop lock / WD 40 for some while! Cheers fellas
751
jcb
704
