Run a scan today and sudden see a lot errors come up that not appear before compare last scan i did 3 month ago. Anyone has similar expierence below error refer to which part broken ?
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT 0003
Coding: 10710
Shop #: WSC 79153
1 Fault Found:
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent
Comment: Sounds like either fuel pump or sensor but not sure exactly which sensor
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
1 Fault Found:
00812 - Brake Pressure Release Solenoid (F84)
Comment: Brake pad going finish ?
Address 08 -------------------------------------------------------
Controller: 8 ? L
Note: Excessive Comm Errors
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 N
Component: KOMBI+WEGFAHRS. VDO D06
Coding: 03844
Shop #: WSC 00020
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
Address 22 -------------------------------------------------------
Controller:
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15183
Shop #: WSC 01236
1 Fault Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
Coding: 10710
Shop #: WSC 79153
1 Fault Found:
Coding: 18448
Shop #: WSC 01236
1 Fault Found:
Controller: 8 ? L
Coding: 03844
Shop #: WSC 00020
1 Fault Found:
Controller:
Coding: 15183
Shop #: WSC 01236
1 Fault Found:
35-00 - -
