i find the total opposite tbh, projectors give far better light output and spread than the older open lamps, even with the same tired old bulbs...
You sure you've got them aligned properly?
Either that or bad connections between the old and new wiring causing voltage drop issues
The main reason being that HID's dont take nicely to being used to "flash" people.quote]
Interestingly, a lot of current BMWs use the HID for dip and main, with dipped beam achieved with a little flap being deployed to cut the top off the light pattern. Said is also used to "flash" main beam when HIDs are on, with a seperate halogen bulb being used for flashing when the headlamps are switched off.
Dunno if any Audis are like that....
have you actually checked the voltage at the bulb terminals with the bulbs on? (ie inside the housing, on the back of the actual bulb itself)
I know in my brothers old nova the 100w bulbs he fitted were barely any brighter, mainly due to the increased current causing more voltage drop on the feed wires so they were getting a volt or so less than the 55w bulbs...
It could, yes. Or melt the headlight switch or cause a fire. This sort of setup requires the circuit to be relayed with thicker gauge wire after the relay to carry the higher amperage required for the bulbs you have fitted. The relays' perpose is to protect your cars stock wiring and switch-gear.Izzy1 said:do you think the 100w bulbs are likely to mess up my wiring or possibably blow my lights?
