mattandrew
- Joined
- Sep 25, 2007
- Messages
- 967
- Reaction score
- 24
- Points
- 18
- Age
- 41
- Location
- Up in the hills, Derbyshire
I have fitted a set of OEM Bi-xenons to my 2004 A3
I have not yet fitted the leveling kit, i have adjusted the screws on the headlights as high as they will go and they are still not high enough. Is there any coding I can do in Vagcom in order alter the height. All the adjuster motors are fitted to the lights and all the wiring is present. Is there any settings i can alter to activate the motors to bring the lights higher.
I know there is a setttng in vaccom to put the xenons into adjustment mode but as I don't have the leveling kit I can't access module 55 in VAGCOM
I presume the kurafec wiring loom must make use of the existing wires on the halogen units for adjusting the lights up and down
I used a wiring loom from kufatec. I had halogens before and my lights work as follows:
Side lights - small side light on
Dip beam - xenon lower shutter
Main beam - xenon lower & higher shutter and DRL
Main beam flash (no other lights on), only the DRL light.
I have coded to say that I have xenons with shutters
Heres my coding
VCDS Version: Release 805.0
Data version: 20080730
Monday,15,September,2008,21:50:59:12592
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77 7D
VIN: WAUZZZ8P54A114429 Mileage: 115660km/71867miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 AT HW: 028 101 145 3
Component: R4 2,0L EDC G000AG 5689
Revision: 12345678 Serial number: AUX7Z0CNFNQ043
Coding: 0000078
Shop #: WSC 66565 257 00032
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 C HW: 02E 927 770 AE
Component: GSG DSG 0623
Revision: 04202624 Serial number: 00000804110712
Coding: 0000020
Shop #: WSC 04940 001 00001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 005784 Serial number: 8P0820043E
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H27 0601
Revision: 00027000 Serial number: 00000000327746
Coding: A788DF00A2141000000000000000000000
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0130
Coding: 0011602
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0013142
Shop #: WSC 12345 123 12345
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 224NCD07002592
Coding: 0000403
Shop #: WSC 00557 210 58459
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103B097EA9
Coding: 3F0F0FC8070101
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D07 Serial number: AUX7Z0CNFNQ043
Shop #: WSC 00340 210 01205
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0300112
Coding: 0209717
Shop #: WSC 74004 146 15103
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000120
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288F0FC85AC65000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 A
Coding: 0000120
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209717
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0001003
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005224949
Coding: 0011422
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
End ---------------------------------------------------------------------
When I activate 55 xenon in the CAN I get the following error, I presume its because I dont have the correct module
Monday,15,September,2008,21:08:47:12592
Control Module Part Number: 1K0 907 530 B
Component and/or Version: Gateway H08 0090
Software Coding: 7F0F0FC8070101
Work Shop Code: WSC 06435
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 115663 km
Time Indication: 0
Date: 2008.09.15
Time: 21:08:27
Heres my coding
Chassis Type: 1K0
Coding: 0000078
Coding: 0000020
Coding: 0023174
Coding: 16711696
Shop #: WSC 00000
Coding: 0011602
Coding: 0013142
Coding: 0000403
Coding: 0209717
Coding: 0000120
Coding: 0000120
Coding: 0209717
Coding: 0001003
Coding: 0011422
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 115663 km
Time Indication: 0
Date: 2008.09.15
Time: 21:08:27
